Quantcast 1984 F350 4x4 6.9 ac stuck on defrost - Ford Truck Club Forum
Old August 1st, 2017, 12:00 PM
pappywith4's Avatar
pappywith4 pappywith4 is offline
Default 1984 F350 4x4 6.9 ac stuck on defrost
Like the title says for some reason my blower only blows out of the defroster!
I change settings but stays the same.
Can some one point me in the right direction?
thanks
Old August 1st, 2017, 10:53 PM
Liked 109 Times in 105 Posts
I don't know when Ford started using vacuum operated HVAC controls, but on later model trucks this can caused by the lack of vacuum to the system. Trace back the vacuum lines, you will probably find one missing, disconnected, or broken. Another possibility is a stuck blend door or bad blend door actuator. The dash control head could be shot.
If it's cable operated, the cable could be disconnected or broken.
Note that diesels have a vacuum pump, there is no manifold vacuum like with gassers.
Old August 2nd, 2017, 06:25 AM
Images: 628
Liked 185 Times in 167 Posts
good advice above ^^
I had a mouse make a nest and block the blend door
look for dropping on floor board and under hood to rule this out
Old August 11th, 2017, 09:08 AM
pappywith4's Avatar
thanks to everyone who replied!
I found where a vacum line was spliced and when I squeezed the joint the vent worked so I found the problem!
I will put a gasket sealer around the ends of the connections and that should take care of it. Thanks again john
For-min , glc , harrison28 , JSoko , pappywith4
Heater won't switch from vent to defrost BigBlue79 1980-1986 Ford Bronco
12 July 8th, 2013 05:06 PM
1984 Mustang GT ?'s JSoko Ford Cars 7 June 24th, 2012 11:24 AM
How to Change the PVC Valve on a 1984 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:27 AM
Now this is stuck! BigT67 General Discussion
5 January 27th, 2010 04:44 PM
I got stuck :( SS FatMan General Discussion
27 November 30th, 2009 10:00 AM
1984 , 4x4 , defrost , f350 , stuck
