Quantcast 2004 F350 XL crew power door locks - Ford Truck Club Forum
Old September 15th, 2017, 06:54 PM
magnum136's Avatar
magnum136 magnum136 is offline
Default Where is the power door lock relay located on 2004 F350 XL crew 4x4 V-10 basic truck
Im testing my basic factory door locks on my 2004 V-10 crew cab 4x4 F350. All four door actuators click about every 20 seconds, neither locking or unlocking, and if I do lock a door it will unlock itself automatically with in 20 seconds. I found that removing fuse # 102 does nothing. Removing the key or starting the truck, makes no difference either. I arrive home from work and I cant lock my doors. If I lock the drivers door when exiting the vehicle, (which should lock all 4 doors and doesn't), then only the drivers door actually locks and it only stays locked about 20 seconds. When I'm driving to work all 4 locks are clicking about every 20 seconds(neither locking or unlocking). I have to remove the battery cable and lock each door manually at night in order to secure the vehicle.
"I'm in need of the exact location of the power door lock relay or relays". My plan is to remove the relays, fuse #102 , and unplug all power wires inside each truck door to kill all power to this door lock circuit, and keep it from draining my battery down when I don't drive the truck every day. I'm looking for the door lock relay(s). There doesn't appear to be a VSM on this basic truck which only has basic power door locks, as its only interior luxury option. Thanks
Old September 15th, 2017, 08:47 PM
magnum136's Avatar
Default 2004 F350 XL crew power door locks
I have a V-10 gas engine. My truck is a basic machine, a crewcab 4x4. I seldom drive it. The door locks are basic with a plain door pad with no control buttons. You push the top door lock/unlock button on either front door to lock all 4 doors and pull either front door lever to unlock all 4 doors. No keyless entry.What happens is none of the door locks stay locked any more than 20 seconds maximum when driving, or sitting still, with the ignition key in or out.. Every 20 seconds all 4 doors will make a clicking sound and it sounds like they were energized, but they neither lock or unlock when this happens. Pulling fuse # 102 in the fuse panel below the steering wheel inside the cab,makes no difference. I cant find a battery junction box fuse to pull out, or the door relay to pull, to kill all power. It appears Ford has eliminated the Battery Junction Box on this 2004 model.I have to remove the battery cable. then lock the doors manually, to secure the vehicle.. I dont see a VSM inside the dash. Where is a fuse or relay that will kill this entire power lock circuit. If I can find the Max type fuse supplying this entire door lock circuit or the door relay(s), I can stop this circuit from draining my battery. . Any help would be appreciated. Thanks
Old September 16th, 2017, 11:04 AM
Liked 110 Times in 106 Posts
http://www.fordservicecontent.com/Fo.../04f23og3e.pdf
All I see is F102.
250/350PS owner , Ford-f250 , glc , harrison28 , magnum136 , Raymondagozy , wce323078
Where is the power door lock relay located on 2004 F350 XL crew 4x4 V-10 basic truck magnum136 1999-2007 Ford F250 | F350
0 September 15th, 2017 06:54 PM
1993 F150 XLT Manual Door Locks. XLTAlex 1992-1996 Ford F150
4 June 22nd, 2015 04:42 AM
2004 F350 Engine Swap ChilliwackFord 1999-2007 Ford F250 | F350
14 May 26th, 2013 10:55 AM
1987 F350: Purpose of Outside Air Door Motor ALEXB 1987-1991 Ford F250 | F350
3 October 4th, 2012 09:46 PM
Door Locks? steverinaz 2004-2008 Ford F150
7 July 20th, 2011 12:39 AM
2004 , 4x4 , basic , crew , door , f350 , located , lock , locks , power , relay , truck , v10
