Quantcast transfer case motor - Ford Truck Club Forum
Ford Truck Club Forum > RANGER | MAZDA-B > 1998-2000 Ford Ranger
Old January 8th, 2018, 10:54 AM
CharlieM's Avatar
CharlieM CharlieM is offline
Default transfer case motor
i have a 2000 ranger XLT 4x4 4.0 and the transfer case motor starting blinking in dash. both 4x4 high and low. no fuses are out I have removed the motor and confirmed motor is not locked up or bad. It has a marking on the inside Arrow. I bumped motor to pointing it together. reinstalled a week went by and its flashing again. How to adjust sensor or what is it doing?
It worked fine after i reinstalled it for a week only used it once then 3 days later blinking the 6x in dash
oh and I replaced it last year not issues till it got bad cold
and help be greatly appreciated
Charles M
2002 F350 XLT 4x4 5.4 Auto
2000 Ranger 4x4 4.0
86 F150 4x4 auto 5.7
Old January 9th, 2018, 03:19 PM
My experience with my 97 f150 is the position sensor is failing and unfortunately its "integrated" or at least not available to be replaced on its own. Mine also barely got used and it failed as well.
You can however make an attempt at cleaning connections and you can check the brushes BUT be aware it isn't the easiest thing to put the damn motor and brushes back together.
Old January 9th, 2018, 08:40 PM
i too have issues with my 97-F150's sensor been going on for years ive given up sometimes it works somtimes it dont
Old January 13th, 2018, 05:22 AM
CharlieM's Avatar
Well i finally got to look thru paper work found where I bought a rebuild one. Auto zone replaced it with a smile and a signature, guess they are know to fail. Lasted only a year
Charles M
2000 Ranger 4x4 4.0
Old January 14th, 2018, 09:01 PM
sounds like a winning deal, keep the paperwork this time too lol
Old January 14th, 2018, 10:38 PM
A good thing about Auto Zone is you don't have to have the paperwork. They can look up your receipt with your phone number.
CharlieM , DoubleDee , glc , harrison28 , JSoko , justin66613 , Klitch , skatebowd
trans/transfer case interchange. jonny99 1948-1986 Ford F250 | F350
0 July 31st, 2014 08:41 AM
transfer case switch ? knifeman 1992-1996 Ford F150
12 March 31st, 2014 04:49 PM
Transfer Case (205) Shifting Linkage mrtief 1948-1986 Ford F250 | F350
0 October 25th, 2013 09:43 AM
Transfer case question BigT67 Ford Expedition 4 November 1st, 2011 01:40 AM
divorced or married transfer case? ASwaff400 1992-1996 Ford F150
7 May 5th, 2010 12:23 AM
case , motor , transfer , x6 flashing
