Quantcast 1981 Temperature? - Ford Truck Club Forum
Old April 29th, 2018, 02:22 AM
NM33013's Avatar
NM33013 NM33013 is offline
Default 1981 Temperature?
Hello, new here. I have a 1981 F100 with a 302 and manual transmission. The truck reads on the “A” of the “NORMAL” lettering on the temperature gauge. Is this acceptable or too hot?
Old April 29th, 2018, 08:20 AM
hard to say
you will need to check the temp
pull the rad cap off & stick a thermometer in there
Old April 29th, 2018, 09:35 AM
Liked 115 Times in 111 Posts
Today's method is use an infrared thermometer at the thermostat housing. It needs to be checked under pressure.
glc , harrison28 , jbsideways , JSoko , MDyce , NM33013
Exhaust Gas temperature monitoring Truckvirgin 2011-2016 Ford F250 | F350
2 August 11th, 2016 01:51 PM
1981 f150 w6930 1973-1991 Ford F150
1 April 25th, 2016 07:59 AM
Exhaust gas temperature monitoring Truckvirgin Garage Talk: Engine & Drivetrain 3 September 9th, 2015 06:51 AM
1981 ltd ASwaff400 Ford Cars 14 July 15th, 2014 06:18 PM
Trouble Starting the Truck/Car? Replace the Coolant Temperature Sensor JSoko Garage Talk: Engine & Drivetrain 0 July 19th, 2012 07:07 PM
1981 , temperature
