Quantcast 2001 f250 superduty tranny slips at anything more then 1/2 throttle - Ford Truck Club Forum
Old January 20th, 2019, 12:09 PM
homey433's Avatar
homey433 homey433 is offline
Default 2001 f250 superduty tranny slips at anything more then 1/2 throttle
I have a 2001 f250 superduty. 5.4l 4x4 with 4r100 tranny. Transmission started slipping at anything more then half throttle. Tried tranny flush and filter. this made no change. note that the tranny fluid was still red when removed. figured after the flush i would just get the tranny rebuilt since the truck has 190000 miles. Put rebuilt tranny in and still have same issues. cooler and lines were also flushed out very well before new tranny went in. If i drive the truck like a civilized person (under half throttle) the tranny will go through all the gears and shift fine. if i put the pedal to the floor the rpms go way up and truck barely moves forward. mainly slips real bad in 3rd gear but has slipped a few times in 1st. also going from 2nd to 3rd gear you have to let off throttle for it to shift. Truck shows no check engine light. but note that even when the truck has spit a spark plug, the check engine light did not come on. I know the truck does have a bit of a misfire right now. could this be it? maybe tps sensor or pcm? trans fluid is mercon and is filled to correct level. new torque converter was also included with tranny.
any help would be great because i have no idea where to go from here. Thanks!!
Old January 20th, 2019, 07:45 PM
Have you scanned the OBD2 for codes? Your CEL is probably burned out.
Old January 21st, 2019, 02:32 PM
The Bone's Avatar
The Bone The Bone is offline
Liked 3 Times in 3 Posts
Did the rebuilt transmission have a new converter with it?
Old January 21st, 2019, 02:43 PM
Sure looks like it......
Old January 22nd, 2019, 10:26 AM
The Bone's Avatar
Ya i missed that last part
Old January 22nd, 2019, 11:36 AM
Could the TBPS act up causing something like that to happen under hard throttle? It sure sounds like this is a computer issue to me.
Old April 8th, 2019, 10:52 PM
Bill2's Avatar
Bill2 Bill2 is offline
Liked 4 Times in 4 Posts
Did you check line pressure in park then through the gears with wheels chalked and in idle.there is a port to test from on side of tranny. Need a gauge that'll read up to five hundred psi just in case.
Bill2 , glc , harrison28 , homey433 , JSoko , mr.c , The Bone
Kane: Young Star Slips Up Bates88 General Discussion
0 August 11th, 2009 03:38 PM
1 or 2 , 2001 , f250 , slips , superduty , throttle , tranny
