Quantcast Check Engine Codes - Ford Truck Club Forum
Old February 20th, 2019, 11:49 AM
Fozzi89's Avatar
Fozzi89 Fozzi89 is offline
Default Check Engine Codes
Good Morning,
I went out to start my 2011 F150 this morning. It attempted to turn over a couple of times then just stops. All the lights are working, the battery is good, but it will not start. The check engine light came on also and gave me three codes:
P0022: Camshaft position timing over retard bank 2
P052D: Cold Start A Camshaft Position Timing Over-Retarded Bank 2
P068A: ECM/PCM power relay de-energized performance too early.
I am not sure how to proceed, and wanted to know if anyone else has experienced a similar issue and how they resolved it?
Old February 20th, 2019, 02:19 PM
What engine?
Old February 20th, 2019, 05:48 PM
Fozzi89's Avatar
Default Engine
3.5L EcoBoost V6
Old February 20th, 2019, 06:35 PM
https://www.obd-codes.com/p0022
https://www.obd-codes.com/p052d
https://www.obd-codes.com/p068a
This sounds like more than a backyard mechanic can handle, but you could at least check fuses and the PCM power relay. It looks like you have an issue with the VVT system.
harrison28 (February 22nd, 2019)
Fozzi89 , glc , harrison28 , The Bone , wce323078
Check engine light Emissions Problem Patch87 1997-2003 Ford F150
8 January 23rd, 2013 02:11 AM
Engine, Tranny, and Rear Axle codes BigBlue79 1980-1986 Ford Bronco
9 October 15th, 2011 05:56 PM
What Does The Check Engine Light Mean? JSoko Garage Talk: Shop Class 101 1 May 5th, 2011 09:13 PM
Ford Check Engine Light nine5flareside Garage Talk: General Tech Talk 0 November 3rd, 2009 10:06 PM
check , codes , engine
