Quantcast i'm all over the road and afraid to drive it - Ford Truck Club Forum
Old March 24th, 2019, 07:04 PM
Mhammers's Avatar
Mhammers Mhammers is offline
Default i'm all over the road and afraid to drive it
I have an 05 F150 fx4 crew cab 5.4L. w/ 6" lift. This truck is all over the road when i drive and vibration around 60 -65 and seems to be getting worse especially around corners. Im at the point where i am afraid to drive it. Its has a rack and pinion steering. I've replace almost everything up front and i'm lost. Here is the list of replaced parts:
New Tires and wheels (35")
Lower Ball joints
Upper control arms
CV axles
brakes
struts
shocks
inner and outer tie rods
sway bar link bushings
U joints
basically every moving part that i thought would cause this. I'm over $2000 invested in parts and 6 months of frustration.
Tires have movement in and out but not up and down when shaken when its jacked up off the ground. There is a clunking in the rack when moving the tire in and out ( attached gif ) but was told this is normal and should not cause the problem im having. Recently its started to make a bad grinding noise when you start to move with the wheel turned, however CV axles are brand new and not rebuilds. Its like its crawling back and forth across the lane when i'm trying to drive straight almost as if i had been drinking and having trouble keeping it between the lines and its getting worse. Now the $1000 worth of tires i put on it are almost bald on the front. I need help this is my only transportation and i really don't want to get rid of it. I'm hoping one of ya'll Ford gurus can help a young man out. Thanks in advance
Old March 24th, 2019, 09:21 PM
Take it to a GOOD 4wd shop and have it thoroughly inspected. Take the tech for a drive.
If it were my truck, I'd ditch the lift kit and put everything back to stock.
harrison28 (March 25th, 2019)
Old March 25th, 2019, 11:30 AM
Grinding noise when turning is usually a bad wheel bearing. How long has the lift been on the truck? Who installed it?
glc , harrison28 , JSoko , Mhammers , RustyPile , sbpbrent
All I drive is F.O.R.D faulkenberrycameron New Member Introductions 5 June 30th, 2013 02:19 AM
my drive to work ASwaff400 FTC Media Center
5 February 24th, 2012 07:37 AM
The BMW 1M: The Last Drive TheSmokingTire The Smoking Tire 0 November 1st, 2011 04:09 AM
I get to drive a big one! MR_Pete 2008-2010 Ford F250 | F350
12 September 25th, 2010 10:23 AM
2005 , 4x4 , 5.4l , afraid , drive , frustration , grinding , hopping , road , shimmering , swerving , vibrations , wheel movement
