Quantcast 1978 F150 400M-Pass Emissions? - Ford Truck Club Forum
Old March 24th, 2019, 09:51 PM
sbpbrent's Avatar
sbpbrent sbpbrent is offline
Liked 3 Times in 3 Posts
Default 1978 F150 400M-Pass Emissions?
I recently purchased this old truck, and I need to pass emissions. There is no catalytic converter, and after researching a bit, the F150's didn't have cat's until MY 1979, but the F100's had them in 1976. The truck runs well, no smoke, and no gas smell in the exhaust after it gets warm. I've looked at a few threads here on the subject, and have come across very little. I'm looking for any advice, from inexpensive potential solutions, to more pricey options. I think I would prefer to keep the 400M and add a 4 bbl carb if I had to do something costly, rather than going to a 460 big block. It may pass, anyway. This thing was well maintained, with new plug wires, and new dual exhaust headers and glass packs. Any advice is welcome, and I am looking forward to interacting with some members. I've kind of lurked here for a while.
Cheers!
Old March 24th, 2019, 11:52 PM
It should pass the way it is unless the carb needs adjustment. It should run lean enough with E10 gas. The only F150's that had cats in 1978 were California spec. What state are we dealing with?
Old March 25th, 2019, 11:25 AM
Another option would be to put smaller jets in the carburetor to lean it out.
Old March 25th, 2019, 12:46 PM
I doubt it would need lean jets - it's going to run lean with E10 to begin with. It's the idle mixture that may need to be adjusted.
EDIT: I see you are in Colorado. For 1981 and older, the only testing is a 2 speed idle test. This should not be a problem if the idle mixture can be adjusted and the ignition system is correctly timed - and as long as the other emissions controls are present and functional. I don't remember what it may have, I know it has PCV, it may have EGR and air injection. There are also items relating to vacuum spark advance. Just take it out for a good run to warm it up and blow it out before you go to the testing station.
harrison28 (March 25th, 2019)
Old March 25th, 2019, 02:32 PM
sbpbrent's Avatar
Excellent glc, and thanks!
Harrison, in Colorado it's 1975. It dovetails with something I found doing research on this:
https://www.thoughtco.com/ford-f-ser...3-1979-3273774
The F100 got its cat's in MY '75. The F150's didn't get them until MY '79. Colorado categorizes '78 and older trucks having a Gross Vehicle Weight Rating (GVWR) of >6100# as "Heavy Duty". '79 and later it's >8500#.
Thanks for the replies!
Old March 25th, 2019, 02:57 PM
sbpbrent's Avatar
I don't think my last post stayed up, but many thanks glc and Harrison. This is an interesting read about cat's in the Ford F series 1973 - 1979:
Old March 25th, 2019, 06:02 PM
The federal break point from 75 to 78 was 6000# GVWR. There were some vehicles less than 6000# that complied with 49 state emissions without cats, most were 4 banger Japanese compact cars and trucks. California required cats on everything starting in 75. 79 and later was cats on everything except some vehicles over 8500# GVWR till 81, starting in 82 everything had cats. My neighbor had a 81 Chevy 1 ton crew cab pickup with a 454 with no cats, but it did have a smog pump. He had a heck of a time getting it past the Illinois inspection without the cats, it took him months to prove to the morons at the state that it never had them.
You know, the F-150 was originally created in 75 for the express reason to avoid cats. They beefed up a F-100 just enough to get the GVWR over 6000#. Chevy did the same thing with the C-10, they called it the "Big 10".
harrison28 (March 26th, 2019)
Old April 5th, 2019, 11:07 AM
sbpbrent's Avatar
Update: It passed emissions easily. I guess I shouldn't have worried about it so much. Now, for the stereo....
harrison28 (April 5th, 2019)
Damienr6 , glc , Gwilliams1961 , harrison28 , oval blues , RustyPile , sbpbrent
1978 F150 IDtag iowaford 1973-1991 Ford F150
1 March 2nd, 2017 02:28 PM
1978 f150 super cab, parts boston buick Auto Parts For Sale
0 August 13th, 2013 09:00 PM
Fuel Capacity in my 1978 F150 Ranger Kenzzz78 1973-1991 Ford F150
6 April 6th, 2013 04:15 AM
2004 F150 Failed Emissions Inspection in PA 2004FX4F150 2004-2008 Ford F150
33 December 21st, 2011 10:19 AM
California emissions vs regular emissions azfarrier 2011-2016 Ford F250 | F350
8 January 7th, 2011 04:10 AM
1978 , 400mpass , emissions , f150
