Quantcast Info on 4r100. Transmission - Page 2 - Ford Truck Club Forum
Old April 13th, 2019, 08:44 PM
Okay, now I understand what you want to do. The only downside of eliminating the bypass is slower warmup. Until the transmission fluid reaches a certain temperature, the torque converter will not lock up. I think I would favor the Dieselsite delete kit.
Old April 13th, 2019, 10:11 PM
Bill2's Avatar
Bill2 Bill2 is offline
Liked 4 Times in 4 Posts
I've been trying to understand why this is a bad thing. Other than if cooler gets plugged or messed up in someway then there's no fluid for back of transmission. If you keep up on everything like fluid changes and filter then I can't see where it would hurt anything. But Mark the smartest transmission guy I know he said it would hurt my tranny and probably destroy it in someway. I kind of see his point but just removing the spring and ball from banjo bolt seems like it would give it better flow. And let it run more efficient and cooler. Whatcha think am I going the wrong way here or what
Old April 13th, 2019, 11:02 PM
I think you should use the Dieselsite kit. As I said, the only downside to more flow through the cooler is slower warmup.
Old April 14th, 2019, 01:14 AM
Bill2's Avatar
Ok thank you for the advice I'll talk to Mark and see if he will think the same way. I really can see much of a down side if I just remove the bottle neck to let it have restrictions
Old April 14th, 2019, 01:15 AM
Bill2's Avatar
Less restrictions is what ment to say
Old April 30th, 2019, 10:03 PM
Bill2's Avatar
Well I put trans gauge on my tranny and got a reading between 140 and 150 seems to be running ok but I pull a 16ft trailer with around 6k pounds and was wondering if you guys think putting a fan on cooler would better my chances on not heating up to much when I tow my trailer
  #17
Old April 30th, 2019, 11:08 PM
You don't need to worry unless the fluid gets over 220 degrees. If you are concerned, a full synthetic fluid such as Amsoil is a lot more heat-resistant than standard fluid.
https://www.amsoil.com/shop/by-produ...?code=ATFQT-EA
harrison28 (May 1st, 2019)
  #18
Old April 30th, 2019, 11:34 PM
Bill2's Avatar
Will amsoil mix with any oil or do I have to do a complete change and is amsoil a Mercon substitute or much better
  #19
Old April 30th, 2019, 11:59 PM
You should do a complete change. Your torque converter should have a drain plug, making it relatively easy. The Amsoil Signature (in my link) is a multi-vehicle fluid, Mercon-compatible, and is considerably better. That's why it's 15 bucks a quart. You will need 17 quarts for a dry fill, even with draining the torque converter a quart or 2 will remain unless you also drop the valve body.
  #20
Old May 1st, 2019, 10:13 AM
Bill2's Avatar
Thanks for the info. But 15 bucks a quart is a lot of money. I'll have to put back a little at a time until I have enough money to do the job. If it's that good how often do I have to change it, every 30k miles??
Bill2 , glc , harrison28
Please help with info!! LtBroseph250r New Member Introductions 3 August 21st, 2016 08:44 AM
VIN Info RKTDR 1997-2003 Ford F150
2 June 9th, 2015 10:56 AM
Need some info blueford 1992-1996 Ford F150
10 December 7th, 2013 10:22 AM
Looking for cam info whitesleeper Garage Talk: Engine & Drivetrain 10 February 19th, 2011 09:56 PM
Info Cajun 1997-2003 Ford F150
2 August 19th, 2010 07:24 PM
info , transmission
