Quantcast 92 F150 5.0 E4OD Not Shifting Code 625 - Page 2 - Ford Truck Club Forum
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Old July 18th, 2019, 08:55 AM
Liked 113 Times in 109 Posts
If the truck starts with the old one, that tells you that the new one is defective.
Old July 27th, 2019, 12:25 PM
jheat's Avatar
jheat jheat is offline
Default Update
Put the old one back in and it fired right up. Returned the bad one and they sent a replacement. Put the replacement in and it fired right up. The transmission is shifting smoothly and is working now. The only fault code I have now is 173 HEGO (HO2S) sensor fault/rich. What can cause this fault?
Thx for all of your help with this.
92 F150 XLT 2WD 5.0 302 E4OD long bed
Old August 3rd, 2019, 10:29 AM
jheat's Avatar
Default Code 173 and 334
Still have codes 173 and 334. Performance is sluggish. Any ideas what to look for?
Old August 3rd, 2019, 11:27 AM
The 334 is EVP sensor - that's EGR valve position sensor. The EGR system needs to be troubleshot. The 173 might be a bad O2 sensor, but it's more likely it's running excessively rich due to too much fuel or restricted air. I'd go get the cat tested for excessive backpressure.
harrison28 (August 5th, 2019)
Old Yesterday, 08:32 PM
jheat's Avatar
I have a new engine code, not sure if I should start a new thread since it is on the same truck. I now have a code 556 fuel pump relay primary circuit fault. The truck will sometimes idle fine other times it idles rough and wants to die and dies when put in drive. After continually starting and dying I will eventually be able to drive it. The truck has a total of 3 codes, 173, 334 and the 556. I know the catalytic converter is bad and the exhaust system needs replaced. The EGR valve, valve position sensor and egr valve control sensor.
Any help on trouble shooting the 556 is greatly appreciated.
Old Yesterday, 10:29 PM
DTC 556 indicates a fuel pump primary circuit failure.
Possible causes:
◾Inertia Fuel Shutoff (IFS) switch not reset or electrically open (if in primary circuit).
◾Open or shorted circuit.
◾Damaged fuel pump relay. (inspect it or swap Horn Relay into socket - assuming horn works)
◾Damaged Powertrain Control Module (PCM).
« 1996 Automatic trans shifter cable | There is no next thread »
(View-All Members who have read this thread : 82
67 Merc 4x4 , Alexemami , AlfredHof , Allahemrt , Alvaroappaf , Anthonysib , Bettybuiny , Billygenna , BrianRed , Brianren , CarlosSv0b , Charlesgrago , Claytonsmemn , Danielfuh , DannyHog , Deannanob , DennisPoili , DennisTed , DonaldVaf , DonaldWoche , doraundissash , EmmittImmap , ErnikaOdowl , EugeneShage , Eurosse , Franciswem , FrankCoosy , GeorgeEtela , glc , harrison28 , her , Irinagluch , Jamesher , Jeffreytep , JesseEcold , Jesseplosy , jheat , KeithFoult , Ken , Kennethdof , KevinDuels , LadonnaCen , LarryVab , LilaBar , MarioDit , MarioThoky , Martynaw , Michaelanify , MichaelJoP , Michaelrar , Mikaelhiz , nydon , Petrrarc , Pharmacevtmi , PollyTek , Ramonvog , Raymondagozy , RobertEmavy , Robertnut , RobertSnubs , RobertVog , RobertVoT , Rodneyvat , RonaldFon , Ronnietah , Russellasymn , SamuelVok , Shanehib , Shirleycrind , TimothyNut , TorqueO , TravisAvell , VitaliyUlcek , Volodimiirkn , Wes , Williamidons , Williamneoni , Williamrhync , Williamsnort , WilliamStali , XRumerTest , ZacharyThync
AOD or E4OD? harrison28 Garage Talk: Engine & Drivetrain 6 January 14th, 2019 12:13 PM
e4od tranny shifting hard moemoe3 1992-1997 Ford F250 | F350
2 September 17th, 2014 11:48 PM
Speedometer & odometer off/ shifting hard LilBit 4x4 1992-1997 Ford F250 | F350
4 July 25th, 2013 07:43 PM
Truck shifting hard Monster 2004-2008 Ford F150
4 February 1st, 2013 03:19 AM
Shifting problem? russ94 2004-2008 Ford F150
3 February 11th, 2012 10:09 PM
625 , clicking , code , constantly , e4od , f150 , relays , shifting
