Quantcast Dana 44 - Operation Break Down - Completed - Page 2 - Ford Truck Club Forum
Old December 31st, 2009, 06:28 PM
DIXIE FIX's Avatar
Images: 504
lookin good. did the guy store it without gear oil in it?
NOTE TO SELF DONT DO THAT:
Old December 31st, 2009, 06:40 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
i think it might of had a shot of preservative water at some point
Monthly Recognition Moderator
Check out my videos HERE
Old December 31st, 2009, 08:34 PM
yeah im not that happy about the surface rust but luckily its just that... surface rust.
Old December 31st, 2009, 08:43 PM
Old Blue's Avatar
Images: 384
ya it wont hurt
Old December 31st, 2009, 09:50 PM
GATOR CREW's Avatar
GATOR CREW GATOR CREW is offline
Images: 19
Hell ya, bout time LOL....look forward to watching this thread
Government is not the solution to our problem. Government is the problem...(Ronald Reagan)
Old January 1st, 2010, 11:29 AM
BADSHOE's Avatar
BADSHOE BADSHOE is offline
Supporting Vendor
You were careful to keep the carrier caps in order because their positions are not interchangeable?
Instructional "How To" videos specializing in Ford drivetrains.
  #17
Old January 1st, 2010, 11:40 AM
I took photos before I touched anything but this axle had already been worked on (taken apart) by the previous owner. He never finished but as you can see, the fluids were already drained and the diff had surface rust. How would one determine the correct way to place the carrier caps?
  #18
Old January 1st, 2010, 12:08 PM
Well after doing some research, it seems that most times the factory will put a mark on the carrier side bearing caps and one on the housing in line with each other so you know what direction to install them in. I will have to take a close look at my pair and my housing... hopefully I have these marks.
  #19
Old January 1st, 2010, 03:36 PM
BADSHOE's Avatar
Supporting Vendor
Frankly, I'm not sure on the Dana's however Ford rears are never marked. If it's been into before, many guys will make the marks your talking about. The Ford 8.8 has arrows pointing out so there's only two possible combos. Mounting the cap on and checking the fit at the mating edge will normally show if it's on the correct side. The alloy IRS 8.8" has no arrows which makes many possible combos. Almost no way to find the right position on those. Remember the Dana's need a case spreader to remove and install the carrier.
  #20
Old January 1st, 2010, 03:58 PM
Old Blue's Avatar
Images: 384
case spreader is a good idea, however it can be done without.... just a little harder and takes more time
« There is no previous thread | Need Help With Dana 44 Build »
BigBlue79 , bulldogginford , CharlieM , CoCrawler , faulkenberrycameron , HiRoller , nydon , pegmeister , Russo2 , Sc4x4truck , whitesleeper
SAS F150 2.5 Ton Monster DIXIE FIX Garage Talk: Solid Axle Swaps 67 October 3rd, 2010 02:31 AM
Need Help With Dana 44 Build nine5flareside Garage Talk: Solid Axle Swaps 2 April 27th, 2010 11:42 PM
ND recruit dies in spring break accident BigT67 General Discussion
0 April 3rd, 2010 10:19 AM
Vented Loudspeaker Enclosure Contruction and Operation SoundScape Garage Talk: Shop Class 101 0 November 27th, 2009 11:33 PM
break , completed , dana , dana 44 , operation , rebuild
