Quantcast Death wobble.... - Ford Truck Club Forum
Old February 25th, 2010, 11:12 PM
lil_bizzy's Avatar
lil_bizzy lil_bizzy is offline
Default Death wobble....
Ok gents, here's the deal. Last fall I bought a 1.5" daystar leveling kit and four used 295/75r16 bfg a/t ko's to put on my truck. Put the leveling kit on with a friend, drove it to the shop the next day to get the tires mounted/balanced. Picked it up, drove just fine. Had no alignment done, and the tires are wearing just fine 6k+ miles later. So, after having these tires mounted up, I noticed that at any speed 63ish+ I get the wobble, which gets stronger until I get to about 80 and then it smooths out a little. This wobble doesn't appear at any other speed, so I assumed it was a cupped tire. I've had this going on since I got the tires/leveling kit. Any idea what it could be? What should I check?
Thanks
- B
Mods: Daystar 1.5" Leveling kit, BFG A/T KO 295/75/16, Black Tough Guy II toolbox, Pioneer head unit, 2 MTX 10's (custom boxes), 250w Bazooka amp, Zstat speakers, Hatchie Bottom seat covers, Mossy Oak mats and steering wheel cover, True dual Dynomax bullets, x pipe, 3.5x18" ss tips (soon), Gotts intake mod, Smoked tails.
Law of the Woods - Eat or be Eaten. - Jack London
Old February 25th, 2010, 11:25 PM
I'd highly recommend getting the alignment done. The leveling kit changed the geometry of the suspension and the alignment corrects that. It could be just out enough to cause the wobble you describe.
Old February 26th, 2010, 12:23 AM
Could be a bad wheel bearing or bearings as well.
Old February 26th, 2010, 04:26 AM
GATOR CREW's Avatar
GATOR CREW GATOR CREW is offline
Images: 19
I would definitely get an alignment done!
Government is not the solution to our problem. Government is the problem...(Ronald Reagan)
Old February 26th, 2010, 09:25 AM
Lostin90s's Avatar
since it started right after lift ,like said get looked at just a slight change in camber will cause pulling .
Check out front end tie rods ,bearings etc they could be going .
Old February 28th, 2010, 07:46 PM
V8_Feller's Avatar
V8_Feller V8_Feller is offline
Images: 1
Your screwing up your suspension and tires by not getting an alignment, causing un-needed and excessive wear. Once you touch anything suspension wise on the front you need to get an alignment immediatly. It took 4 trys to get my alignment right again, I finally got my alignment into spec.
The wobble could be bad alignment, wheel bearing, loose steering component, loose UCA's.
2004 F-150 Heritage 4.6
218.7 RWHP, 3980 lbs, 0-60 7.72 seconds :)
BIGCOUNTRY , dranger962000
death wobble The-LI-Redneck Garage Talk: Shop Class 101 29 January 3rd, 2010 08:42 PM
Moose a suspect in woman's death BigT67 General Discussion
0 November 30th, 2009 11:25 AM
Bug spray eyed in death of 10-month-old boy BigT67 General Discussion
0 November 3rd, 2009 03:40 PM
Man On Ride-Along Stomps Opossum To Death BigT67 General Discussion
7 October 22nd, 2009 10:54 AM
Boy, 11, dies while stranded in Death Valley BigT67 General Discussion
0 August 8th, 2009 03:23 PM
death , wobble
