October 19th, 2011, 03:21 PM
Trans codes
P0503 and P1500
P0503 Vehicle Speed Sensor (VSS) A Intermittent/Erratic/High
P1500 Vehicle Speed Sensor Intermittent
I've asked this in another board, but of course I'm like black listed nobody will say a word, VERY aggravating.
On the 1997 F150, there is a black or brown wire? Ok lets call it a dark wire, that comes from the harness and passes through the tail housing into the t-case. I'm unsure what that wire does, I'm curious if thats the root of my problem this time or if the plastic drive gear is actually slipping on the output shaft again. A previous owner did not remove the pin and wire from the connector, cut and spliced it instead. I'm wondering if that has failed finally.
October 20th, 2011, 12:48 AM
Klitch, pardon if i ask a dumb question here.. is there a wheel sensor also? or does it come from the trans alone?
reason for the question is i had a - ok dont laff - crysler (dont want to speeelll it right - it was a POS!) and i had gobs of problems with the trans not shifting correctly. Seems the wheel sensor (rt frnt) didnt jive with what the TCM or it's sensor saw and it gave simular errors that the dealershit (spelled that one right) couldnt figure out until i went to a different non-dealer mechanic. B/L was, the wheel sensor was not only bad but the mech said it was set at an incorrect air gap. Debris ?..?
Anyhow the result between the two confused the TCM. They changed the wheel sensor and there was peace in the kingdom.
October 20th, 2011, 08:37 AM
maybe start with seeing if that wire has power, while going through differant modes (key on/off, gear changes, 4WD engage/disengaged) you get the idea
October 20th, 2011, 03:27 PM
I do believe, with a little doubt in myself, that the 97's used a speed sensor on the t-case and trans? Later models used the speed sensor in the rear diff?
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 14
BigBlue79
Bulldog74
DoubleDee
gadget
HawaiianF150
JSoko
katrobb@live.com
Klitch
nine5flareside
Russo2
sbellinghausen
TheAmplified42
whitesleeper
xxpaintballxx
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Engine, Tranny, and Rear Axle codes
BigBlue79 |
1980-1986 Ford Bronco
9 |
October 15th, 2011 05:56 PM |
trans fluid change
Stewy 39 |
1997-2003 Ford F150
13 |
July 10th, 2011 10:53 AM |
1978 f250 trans
originalrider41 |
1948-1986 Ford F250 | F350
1 |
March 24th, 2011 06:02 PM |
My codes 172,175,1137,1157
Klitch |
1997-2003 Ford F150
19 |
September 20th, 2010 05:52 AM |
E4OD Trans Slipping
nine5flareside |
1992-1996 Ford F150
3 |
July 27th, 2010 08:34 PM |
