Quantcast 1988 F150 thread - Page 3 - Ford Truck Club Forum
  #21
Old January 14th, 2012, 12:33 PM
Originally Posted by big_blue79 View Post
It is eating the third flexplate and the fifth starter.... Solenoid has been replaced and this starter is only a couple months old since I exchanged it for another.
you may need to add or remove shims
or they have been giving you the wrong starter even if the part # is correct there are differances on the bolt face thickness
  #22
Old January 14th, 2012, 07:11 PM
Well, the 88 got an oil and filter change, new Autolite spark plugs, new plug wires, washed it and waxed the wheels:
  #23
Old January 14th, 2012, 07:21 PM
Looks good, doesn't look like it has a tranny cooler, does it?
  #24
Old January 14th, 2012, 07:53 PM
IDK didn't really have a good look, did find a broke plastic vac hose for the big can on the passenger side fender, I think it works cruise?
  #25
Old January 14th, 2012, 08:03 PM
The can that is literally a soup can? It's an evap can.
The cruise "can" is the one on the drivers side fender and looks completely different. It's bolted onto the fender right by the master cylinder.
  #26
Old January 14th, 2012, 08:06 PM
Yep, the "soup" can, looks like I'll be doing the rubber vac hose swap booba.
  #27
Old January 14th, 2012, 08:09 PM
It's not an Evap can, its a vacuum canister for the AIR system, and supplies vacuum to the TAD\TAB solenoids when the motor isn't creating enough vacuum to actuate the valves. From the looks of behind the grille, theres no transmission cooler. If you ever do anything to that truck add a cooler and a remote filter. It makes the AOD go from a 90,000 mile transmission to 260,000+ mile transmission.
  #28
Old January 14th, 2012, 08:21 PM
You're right booba sorry, I got the coffee cans mixed up with the actual evap canister, that is plastic and in the same general area.
  #29
Old January 14th, 2012, 08:24 PM
Yep, damn thing is in the way when I put e-fans in. Nothing a Dremel didn't fix(on the e-fan).
  #30
Old January 14th, 2012, 09:15 PM
The cab and fenders have the only good paint, the hood has some gnarly gashes in it and the bed is flaking paint, it is already to the base primer. So, I've gotta get paint by using these two paint codes, 2D 1G.
87F150Jess , 90f150xltcenturion , akzep69 , BigBlue79 , bikertrash3531 , bluemoose , Booba5185 , cschneid13 , DoubleDee , F150GT , Ford-f250 , FXRS , HawaiianF150 , Hhaley0991 , hillbillypajeeps , i6lover , IrishKRO , jhollow10 , jhow88 , JSoko , kbmoss , malooman , matttola , mylife69 , nevadaford , nine5flareside , Ol Red , Red91 , Ridgerunner , RKTDR , Rudystruck , Run91 , Russo2 , scbill , Scorekeeper58 , Sean , skatebowd , Timmy Torque , triston , windigowolf
FTC Voting Thread nine5flareside General Discussion
7449 May 8th, 2018 01:54 PM
1988 f-150 i need used parts tooturbugg22 Auto Parts Wanted
2 February 13th, 2013 07:03 PM
1979 F150 Custom build thread BigBlue79 1973-1991 Ford F150
7 March 9th, 2012 10:21 PM
1988 F150 Instrument Cluster Question BigBlue79 1973-1991 Ford F150
21 January 12th, 2012 07:19 PM
1988 , f150 , thread
