Quantcast 1988 F150 thread - Page 43 - Ford Truck Club Forum
  #421
Old July 8th, 2012, 01:34 PM
Oh and the old coil threw 7.1Ohms through my Multimeter.
  #422
Old July 8th, 2012, 01:56 PM
The MAP sensor is what tells the EEC what the engine's current vacuum is. It's one of the major sensors that the EEC uses to make it's A\F mixtures.
  #423
Old July 8th, 2012, 03:59 PM
Well either way it goes, the MAP has 4.5v going to it and no vac leaks. Could it be bad or would the truck not run?
  #424
Old July 8th, 2012, 07:29 PM
Truck is back in timed, 10* degrees BTDC, and running great! Gonna wash it. And take pics!
  #425
Old July 8th, 2012, 08:44 PM
That's done whew, I forgot to put the #1 plug wire back on as I had to fix the boot, and test drove it, couldn't figure out why the truck had a weird ass vibration then it dawned on me ......
  #426
Old July 8th, 2012, 08:51 PM
Still need to vacuum it tomorrow unless we get rain .
  #427
Old October 14th, 2014, 11:10 AM
Sean's Avatar
Sean Sean is offline
Default rear fuel lines
It's hard to form a picture of your directions but hopefully I can figure it out. You were addressing a different year truck also. My problem is that I removed the rear gas tank and now need to stop the fuel lines from leaking...so I was going to explore and see what I can do. There isn't much sense in my investing to much in this truck since I only need it for local use. The lines were damaged and now I need to figure out if I can simply remove them. Or,apply your solution. I don't understand the removing of the plug in the front tank?? Sean
  #428
Old October 15th, 2014, 07:47 AM
with over 400 post
not sure what your referring to
quote the post
87F150Jess , 90f150xltcenturion , akzep69 , BigBlue79 , bikertrash3531 , bluemoose , Booba5185 , cschneid13 , DoubleDee , F150GT , Ford-f250 , FXRS , HawaiianF150 , Hhaley0991 , hillbillypajeeps , i6lover , IrishKRO , jhollow10 , jhow88 , JSoko , kbmoss , malooman , matttola , mylife69 , nevadaford , nine5flareside , Ol Red , Red91 , Ridgerunner , RKTDR , Rudystruck , Run91 , Russo2 , scbill , Scorekeeper58 , Sean , skatebowd , Timmy Torque , triston , windigowolf
FTC Voting Thread nine5flareside General Discussion
7449 May 8th, 2018 01:54 PM
1988 f-150 i need used parts tooturbugg22 Auto Parts Wanted
2 February 13th, 2013 07:03 PM
1979 F150 Custom build thread BigBlue79 1973-1991 Ford F150
7 March 9th, 2012 10:21 PM
1988 F150 Instrument Cluster Question BigBlue79 1973-1991 Ford F150
21 January 12th, 2012 07:19 PM
1988 , f150 , thread
