Quantcast Muzzle Loader info - Page 5 - Ford Truck Club Forum
Old March 23rd, 2012, 10:24 PM
That's the Rifle I have, I could buy a 209 shotgun primer conversion to make it a supposedly "more reliable" gun, I've shot dad's Hawken with a #11 in the rain and they are pretty reliable. Plus the conversion kit costs $44.95 now.
  #42
Old March 24th, 2012, 11:39 AM
Originally Posted by Ridgerunner View Post
Why can't you modify your gun? In Pale rider he used cartridges.
this post is in reguards to his ThunderHawk rifle
this issue has been resolved
you would have to go back and read all that is posted
infact a good read if you'er planning on a black powder
  #43
Old April 19th, 2012, 06:21 PM
So "lonewolf" I've been doing some research, my Thunderhawk has a 21" SS Barrel with a 1:38" twist, not ideal for round ball ammo, I've been shopping around for the Powerbelts locally, and came across these at the local Academy sports:
Specs:
PowerBelt AeroLite .50 Caliber 250-Grain Ammunition
  • .50 caliber
  • 250 grains
  • 15-round box
  • Snap-on base creates a gas seal to provide consistent pressure and accuracy
  • Great flight performance to offer long, flat trajectories and controlled expansion
  • Large, hollow-point cavity reduces weight and helps maximize expansion
  • Polycarbonate tip preserves aerodynamic integrity and prevents premature expansion
  • Smooth, plated finish
  • Fluted, large-diameter gas check helps enhance shot-to-shot consistency
  • Ideal for deer, elk, black bear and other large game.
15 of those is $26.99, these aren't plastic coated, I thought about trying them. I'll elaborate more on the 1:38" twist in this gun for the newer n00b's, the 1:38" twist is a faster twist than what my father's T/C Hawken has(1:48") which isn't very good for round ball, it'll spin it but will probably only hit something to about 50-60yrds out and then drop like a hotcake.
I haven't had the time to go by the store and buy these, nor powder so I haven't shot it yet.
"Thunderhawk" over.
  #44
Old April 20th, 2012, 01:26 PM
'ThunderHawk'
I have'nt seen that one before, must be new
I'm not a fan of lead bullets in a muzzeloader, just adds to the fouling
I use the copper clad 'Aero Tip'
the slower rate of twist 1:48 & 1:66 are best with a patched round ball. With the 1:66 being the best.. and a 1:32/38 best for conical bullets
Probably the most important factor to consider in bullet selection is the rate of twist in the rifling of your gun. In a rifle with a 1-66" twist, you will usually use a round ball with a cloth patch.
If your black powder firearm is equipped with a 1-48" twist barrel, you have the choice of a patched round ball and "mild" powder charge ( a heavy charge may cause the patched ball to strip out and not follow the rifling, thus reducing accuracy), or a conical bullet of some design of your choosing. Since 1-48" is a compromise twist and not really very fast, you would probably find better accuracy with a shorter slug. For example, in the case of a .50 caliber maxi ball, you can pick from a 320 grain, 370 grain or 460 grain bullet. Going back to the rule that as the bullet gets longer the rate of twist needs to be faster to stabilize, and recognizing that 1-48" is only a medium rate of twist, then theory would say to use the shorter, or 320 grain, bullet.
In fast twist guns (1-32" or faster), you can probably forget round ball & patches, unless you want to play with very light powder charges to find an inexpensive "plunking" load. This is because a ball and patch may be 1/3 to 1/2 the price of a conical. A fast twist gun will actually shoot most any conical on the market.
There is no one "right" answer to the question of the proper bullet. Try several bullets to find out which your rifle likes the best
'LoneWolf' OUT
ASwaff400 , BigBlue79 , DoubleDee , JSoko , nine5flareside , Ridgerunner , Russo2
old info needed whitesleeper Ford Cars 12 January 1st, 2012 10:47 AM
O2 Sensor Info JSoko Garage Talk: Shop Class 101 0 October 13th, 2011 10:56 AM
Looking for cam info whitesleeper Garage Talk: Engine & Drivetrain 10 February 19th, 2011 09:56 PM
Info Cajun 1997-2003 Ford F150
2 August 19th, 2010 07:24 PM
Need some info about bikes. LilBit 4x4 General Discussion
68 October 20th, 2009 04:44 PM
clean , info , loader , muzzle
