Quantcast 1995 f150 problems - Ford Truck Club Forum
Old March 6th, 2012, 10:33 PM
mucklife13's Avatar
mucklife13 mucklife13 is offline
Exclamation 1995 f150 problems
I got a 95 f150 with a 5.0 lastweek it started running rough back firing and bogging down when I try to drive it I cant figure it out I unhooked the cats thinking they were clogged, changed the o-rings for the injectors, did a tune up, check the fuel pressure changed the fuel filter, then I looked at the fuse box inside the cab and seen it was fried, so I changed the wiring harness inside for the fuse box but still doin the same deal. I hooked up a scanner and a code came up for the map sensor and there isn't one. Any ideas on what it could be will help im tired of driving my gfs mazda3 I want my truck back lol
Old March 7th, 2012, 08:03 AM
Dirty MAF sensor and/or air filter?
Bad O2 sensor?
Does the engine vibrate? Bad spark plug/plugs?
Old March 7th, 2012, 10:45 AM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
Did you check the timing during your tuneup?
Big T
Old March 7th, 2012, 11:11 AM
good call, T
Old March 7th, 2012, 11:32 AM
some food for thought
the o2 sensor can go out causing problems one to be the flooding of the CAT, I know this from personel experience
read this
http://www.fordtruckclub.net/forum/s...ead.php?t=5537
http://www.fordtruckclub.net/forum/s...ead.php?t=5746
read this on a MAS sensor
http://www.fordtruckclub.net/forum/s...ead.php?t=5536
http://www.fordtruckclub.net/forum/s...ighlight=clean
MAP sensor
http://www.fordtruckclub.net/forum/s...ead.php?t=5368
I think the sensor located on the firewall
check youe under hood vacuum route diagram or get a Hanyes Manual or go to the parts store and page through one
on a new to you Truck a MANUAL will be your best Tool
http://www.supermotors.net/registry/media/825935
http://www.supermotors.net/registry/media/245234
http://www.supermotors.net/registry/media/826382
also: on a MAF engine. It was optional in '94-95; standard in '96. Does your air filter cover have 2 outlets, or just 1 with a Y between it & the engine?
if so just the MAP sensor (speed-density) its mounted to the evaporator housing above the R exhaust manifold.
Old March 7th, 2012, 07:06 PM
mucklife13's Avatar
i checked the timing its good got a new maf sensor. unhooked the cats. i went to change the map sensor but it dont have one (or i just cant find it) but i checked on google to see where it might be and a picture came up and showed a vacum hose running from the top of the intake to the map sensor but the one its suppose to be is capped off. so im lost with this deal
Old March 7th, 2012, 08:41 PM
well I have given all the digrams I know
Old March 7th, 2012, 09:47 PM
mucklife13's Avatar
Im gonna take a look and read the links you sent and see if I can figure out anything thanks for the links
Old March 7th, 2012, 09:50 PM
there were some weid changes between '95 -'96
on the emission's
MAF&MAS
some had some, some had none
Old August 4th, 2012, 11:50 PM
mattcoltharp's Avatar
mattcoltharp mattcoltharp is offline
Default well?
Did we ever figure out what the problem with this was? I am having the same issue. I have replaced the fuel filter, spark plugs, plug wires, cap, rotor, oil sender unit, "about to give an oil change but thats besides the point, I have added a cold air intake and removed the muffler b4 the issue started but have drivin around for 3 or 4 weeks b4 the issue started. Have done everything it says I can do with seafoam to the truck. So have we figured anything else out?
Jr.Muskrat
(View-All Members who have read this thread : 28
ASwaff400 , Big Black 007 , BigT67 , BigTrouble , bikertrash3531 , Booba5185 , Damienr6 , DBRN409 , DoubleDee , fordboyhounddog , JSoko , judd94 , LtBroseph250r , matt0106 , mattcoltharp , michaelsnodgrass18 , mucklife13 , nine5flareside , Ridgerunner , Russo2 , Scuba steve , The Frankster , tinker1980 , txweslawyer , tylerbotts , whitesleeper , woodrock , x1488x
1995 F150 - Need Help! nine5flareside 1992-1996 Ford F150
29 January 15th, 2012 07:54 PM
1995 f150 vids ASwaff400 1992-1996 Ford F150
1 September 20th, 2011 05:53 PM
1995 F150 Misfire nine5flareside 1992-1996 Ford F150
10 June 14th, 2011 08:07 AM
F150 Problems zippois1 1992-1996 Ford F150
1 February 5th, 2011 08:14 PM
1995 F150 Video nine5flareside 1992-1996 Ford F150
2 December 13th, 2010 09:23 AM
1995 , f150 , problems
