Quantcast 1995 F150 Dead Fuel Pump - Ford Truck Club Forum
Old June 6th, 2012, 01:07 PM
Default 1995 F150 Dead Fuel Pump
So after drivng around NJ with Double Dee, towards the end of the night my truck started acting funny and the check engine light was also on. Went to start her up this morning and she gave a little issue but ended up starting. Got to point A, did what I had to do, now it was time to go to point B and the truck just wouldn't start.
I tried everything known to man, banged the starter, checked fuses under the hood etc. etc. etc. but nothing. I put some ether on the air filter and the bitch almost started right up.
I then put the key on truck off and pushed the nozzle on the fuel rail and no fuel came out...
I had someone bang the fule tank with a rubber mallet while I started it and guess what... it started! I got it home and then shut it down and tried to start it again for shits and giggles and guess what... it didn't start!
Old June 6th, 2012, 01:11 PM
Story or trying to ask for help?
Old June 6th, 2012, 01:53 PM
Well I know what the problem is so...
Let's see though, anyone ever remove an intank electric fuel pump from a 92-96 F150/Bronco?
If so, what tools do I need, should I replace the fuel tank straps? Any info is greatly appreciated!
Old June 6th, 2012, 02:07 PM
You'll need a Hammer, a Brass Punch, the tools to take the straps off, a jack if it's full of gas, and that's all I can think of.
I'd replace the straps only if they are rusty or look rusty.
Old June 6th, 2012, 02:33 PM
Can you offer any part numbers from lets say advance auto or summit racing?
Old June 6th, 2012, 03:17 PM
Before going to allthat trouble check your connections at the tank itself. Reach around the top of the tank, in plug it, then use your multimeter to check for +12v. The fact that it turned on when hit with a hammer can just mean it has a flaky connection.
If you do end up having to change the pump, I've always done it the lazy way and pulled the bed..
Old June 6th, 2012, 03:35 PM
I'll need the size of tank nine5.
Booba, that reminds me of sixlitre cutting a hole in the cargo area of his 85 Bronco and making it a hinged floor plate so he can have quick access to the fuel pump.
Old June 6th, 2012, 03:40 PM
Oh and the reason for the Brass punch for those that don't know is when tapping the lock ring off of the fuel pump with a steel punch it'll spark, Brass won't spark against it when tapping, it is softer though so don't hit it real hard.
Old June 6th, 2012, 04:08 PM
The bed is so easy to remove on these trucks, especially a short bed, lol.
Old June 6th, 2012, 04:15 PM
Ask ridge how hard it was to get the nuts off of the bolts holding the bed on that 85..
ASwaff400 , BigBlue79 , Booba5185 , DoubleDee , HawaiianF150 , judd94 , Klitch , michaelsnodgrass18 , nine5flareside , RichardGunz , Russo2 , steve95 , TheAmplified42 , TnFord
New to me 1995 F150 tinker1980 New Member Introductions 6 May 3rd, 2012 11:29 PM
Fuel Pump Relay Ridgerunner Garage Talk: Shop Class 101 6 March 26th, 2012 06:21 PM
1995 F150 - Need Help! nine5flareside 1992-1996 Ford F150
29 January 15th, 2012 07:54 PM
1995 f150 vids ASwaff400 1992-1996 Ford F150
1 September 20th, 2011 05:53 PM
Smog Pump Removal 92 - 96 F150 nine5flareside 1992-1996 Ford F150
14 January 7th, 2011 08:42 PM
1995 , dead , f150 , fuel , pump
