Quantcast Check engine light Emissions Problem - Ford Truck Club Forum
Old November 1st, 2012, 12:21 PM
Patch87's Avatar
Patch87 Patch87 is offline
Default Check engine light Emissions Problem
I have a 2000 Ford Expedition with I believe a 4.6 liter. I keep getting a check engine light caused by an emissions problem. I replaced the "see attachment" last year the car passed inspection but the emissions problem keeps reoccurring. Any Ideas on how I can Permanently solve this?
Thanks
Old November 1st, 2012, 12:25 PM
what is the code that it throws
Old November 1st, 2012, 03:08 PM
Patch87's Avatar
P0401 EGR FLOW Insufficient
Thanks
Old November 1st, 2012, 06:23 PM
The peice you pictured controls the EGR via vacuum, so the problem could also be a vacuum leak, a bad EGR valve, or a bad connection leading to this solenoid (what you pictured). Unplug the vacuum line leading from the solenoid to the EGR valve, and put your finger over the hose while the truck is idling, you should not feel suction. If you do, shut the truck off, unplug the solenoid, start the truck up and put your finger on the hose again. If you still have suction, then the solenoid is indeed bad and you need to replace it with a better brand.
If you unplug the vacuum line going from the EGR solenoid to the EGR valve and do not have any suction on the vacuum line (while the truck is running), then get a small length of (clean) hose, connect it to the EGR valve and suck on the hose (with a vacuum pump or your mouth). The engine should run like poop when you do this aand damn near die. If it makes no difference, then the problem lies inside of your EGR valve. It's clogged, or down right bad.
If you suck on the hose and the engine DOES fall on it's face and die, then the EGR valve is most likely fine. Reconnect the vacuum line going from the EGR solenoid to the EGR valve. Disconnect the OTHER vacuum line coming off of the EGR solenoid and check for suction. This hose should have suction at all times (as long as the engine is running of course). If there is no suction on that hose, then you have a vacuum leak or the hose itself is disconnected from the engine (intake manifold).
If your truck passes all these tests, then the sensor on the EGR valve itself (which tells the computer if the EGR is moving or not) it most likely bad, and will need to be checked and\or replaced.
Old November 3rd, 2012, 12:56 AM
Liked 115 Times in 111 Posts
The most likely problem with a 4.6 is plugged EGR passages in the throttle body elbow.
The part you replaced is called a DPFE.
Old November 9th, 2012, 10:47 AM
Patch87's Avatar
Thanks to all for the great info. I will post when I solve the problem.
Old November 9th, 2012, 07:25 PM
hopefully it's nothing major
Old January 22nd, 2013, 05:09 PM
notasinger's Avatar
notasinger notasinger is offline
You probably have a plugged throttle body as mentioned above. I have a 99 4.6 with 195,000 and mine was pretty much clogged solid.
Old January 23rd, 2013, 02:11 AM
jovanlopez90's Avatar
jovanlopez90 jovanlopez90 is offline
it a common issue could be a clogged egr pasage or the dpfe i got the same code for 8 months now
ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , brick13 , DoubleDee , glc , GunSlingR69 , JerryR , jovanlopez90 , JSoko , notasinger , Patch87 , Russo2 , skatebowd
Emissions Removal Ridgerunner 1973-1991 Ford F150
12 April 13th, 2012 08:12 PM
What Does The Check Engine Light Mean? JSoko Garage Talk: Shop Class 101 1 May 5th, 2011 09:13 PM
California emissions vs regular emissions azfarrier 2011-2016 Ford F250 | F350
8 January 7th, 2011 04:10 AM
LED Tail Light Problem hmrhed1 2008-2010 Ford F250 | F350
14 October 20th, 2010 03:46 PM
Ford Check Engine Light nine5flareside Garage Talk: General Tech Talk 0 November 3rd, 2009 10:06 PM
check , emissions , engine , light , problem
