Quantcast Changing plugs and plug wires - Ford Truck Club Forum
Old November 24th, 2012, 09:06 PM
Shade's Avatar
Shade Shade is offline
Default Changing plugs and plug wires
First things first. Thank yall for helping find the short in my turn signals. Evidently there were two modules, one further back that was shorting everything. $400.00 bucks later, she's up and running like a top. So once again, I come to pick your brains.
I need to change my plug wires and plugs in my 99 250 SD with the V10. What plugs do you use? I'm thinking Motorcraft should be fine but open to suggestions.
Also, another question. Every so often I'll get in and hit the key and you'll hear the starter spin, but she won't crank. I'll turn on it off and on for a few minutes, turn the key off, take it out and then put it back in and it'll fire and run smoothly. It's a sporatic issue but one that worries me. My dad thinks it's the starter having a few teeth off but I thought I'd ask yall as well.
So, summary: What plugs and plug wires do you use?
Old November 24th, 2012, 09:29 PM
Shade's Avatar
Also, are there only 10 plugs or is it like my 08 Ram was with 2 plugs per cylinder?
Old November 24th, 2012, 10:55 PM
The starter sounds like it's going bad completely, all it does is spin and not move forward, I've had that happen several times, specially after a long engine cranking session..
I'd use Motorcraft plugs and wires. Can't go wrong with what came in it.
Old November 25th, 2012, 12:10 AM
Shade's Avatar
What plugs though? What part number?
Old November 25th, 2012, 01:40 AM
1 plug per cylinder
Old November 25th, 2012, 02:05 PM
Motorcraft Part No. SP465 Copper Core Spark Plug
You could even go with Autolite's, that's what I'm running, they just make them in China now, that's why I didn't mention them . Part No. 103
Your choice.
Old November 27th, 2012, 08:34 PM
Shade's Avatar
Thank yall very much
Old November 27th, 2012, 08:36 PM
Shade's Avatar
What should be on my list to change out at 200,000 miles? Well, 210,000. I picked her up at 208k and changed the oil and tires, but what else do I need to do?
Old November 27th, 2012, 08:47 PM
Tranny flush and refill, check gear oil, check/replace air filter, check your battery acid level, coolant flush and refill.
Old November 27th, 2012, 08:52 PM
Since it has 200k and is new to you, i would just give it a thorough going over. Check belts, hoses, any vaccume lines, fuel filter, test coolant if no good then flush, check trans and diff fluid, if the diff fluid is murky change it, check rubber brake lines for cracking or leaking. Your a miltary man, just give it a good PMCS.
ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , gtstang , Jbigfoot21 , JSoko , Rcramer , Russo2 , Shade
Splice Automotive Wires-How to JSoko Garage Talk: Shop Class 101 0 May 19th, 2012 09:21 PM
How to Spark Plug Wires JSoko Garage Talk: Shop Class 101 24 December 15th, 2011 02:04 AM
Quick Tips - Changing Spark Plugs Gearz Gearz 0 March 23rd, 2011 05:27 PM
How to replace spark plug wires JSoko Garage Talk: Shop Class 101 4 March 16th, 2011 09:09 AM
How Spark Plug Wires Work JSoko Garage Talk: Shop Class 101 0 March 15th, 2011 04:48 PM
changing , plug , plugs , wires
