Quantcast Just bought my 92 f150 sc 2wd lgbd 5.0 - Ford Truck Club Forum
Old November 29th, 2012, 08:49 PM
GSID39's Avatar
GSID39 GSID39 is offline
Default Just bought my 92 f150 sc 2wd lgbd 5.0
Alright i found a great truck for 1850. My 92 ford f150 only has 64000 on it. Its a great story but i will get to that some other time. The day i bought it i notice that the trans gasket was leaking and i figured being it was from up north now its a florida truck maybe it had just dried up, so i bought a new gasket and filter to change it which i had never done before so when i changed them i didn't no about torquing the the 9-11 bolts and i put it back together and no leaks! Great job so i thought the same day i change the thermostat which was in the open position and stuck so while changing that the climate control temp sensor but it had broke so i replaced it then put everything back together but, i only put mostly water for now until this wknd in the radiator.So i have gone back pulled the tranny pan and filter and replaced it all and did torque it again and im ready to roll! So then i take it for a ride to check everything and now i have a (3/4 shift and when letting off gas it gets kinda rough?) It was smooth and riding great before i touched it now im stressed anyone have any advise?
Old November 29th, 2012, 08:52 PM
Get the right filter for the transmission? Running the right type of Fluid in the transmission? Proper fluid level?
Old November 29th, 2012, 09:03 PM
GSID39's Avatar
yes matched it with the OG filter and same fluid tranny called for , and level is good.
Old November 29th, 2012, 09:15 PM
How are you checking the fluid? Transmission should be in neutral and warm, with engine running.
Old November 29th, 2012, 09:24 PM
Shift through all the gears after it's warmed up, then check the fluid level.
90f150xltcenturion , audioface , BigBlue79 , Booba5185 , GSID39 , Herbie , michaelsnodgrass18 , rikard , Russo2 , The Frankster , woodrock
Bought a parts truck. bikertrash3531 1992-1996 Ford F150
6 June 24th, 2012 02:30 PM
2004 F150 Window Vent Visors - Just bought them! 2004FX4F150 2004-2008 Ford F150
22 October 26th, 2010 02:49 PM
Bought A New Water Pump nine5flareside 1992-1996 Ford F150
1 August 14th, 2009 09:55 PM
2wd , bought , f150 , lgbd
