Quantcast Motor Rebuild - Ford Truck Club Forum
Old February 13th, 2013, 12:16 AM
fullthrottle95's Avatar
fullthrottle95 fullthrottle95 is offline
Default Motor Rebuild
Hey. Does anyone have any ideas they would like to share on a good rebuild on a 351 V8 motor?? If so please share. Looking for ideas.
Old February 13th, 2013, 02:15 AM
Get a block from a 1994+, since it'll be roller, find some good heads for a 302 (GT40 or GT40Ps for the budget minded) and have the head bolt holes drilled out to 1\2 (instead of 7\16) inch, and save for an edlebrock intake (351 intakes suck), get a good roller cam, a Mustang HO cam does well if you advance it(also for the budget minded). If your truck is not MAF then you'd probably need to convert, which is actually one of the easiest things I've ever done to my truck.
Old February 13th, 2013, 01:41 PM
What he said. With one exception. Instead of a Mustang cam see if you could find a Lightning cam.
Old February 13th, 2013, 04:56 PM
Lightning is flat tappet, can't be used in a roller setup.
Old February 13th, 2013, 06:42 PM
Thought they were roller. Oh well, nevermind then.
Old February 14th, 2013, 02:30 PM
Thanks guys. But i dont know. I have a 1995 ford f150 xlt 2x4 auto with the 351 in it. My plans so far is to make it a 4x4 5 speed. throw a 6 in or 8 in suspension lift on top of a 3 in body and make it more of a play toy. But street legal. I want to do a lot more than just that and would love to build my own bad ass motor to put in it. Any help with that?
Old February 14th, 2013, 04:01 PM
Do yourself a favor ans start with a solid axle rather than lifting the ttb. If you have a long bed truck you can use 8" lift springs without much trouble, if it's a short bed your rear driveline angles might be too tight, unless you want to get a custom high-angle shaft.
You will need a a zf5 from a 3/4 or 1 ton truck, has to be a gas version small block pattern not a 460. The m5 will never hold the power of a built 351.
Good luck on the build
Old February 14th, 2013, 04:58 PM
I would love to keep and build up the 351 for it tho. Its an extended cab long bed. Huge work in progress. Its my daily driver right now so i would like to start ordering the parts and that now so when the summer comes around i can yank the motor out and get that done and put back in right away. I will post pictures of it sometime tomorrow once i figure out how to.
Old February 14th, 2013, 07:26 PM
get friendly with your local machine shop
and prepare for a week or more of down time
6staysdirty , ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , fl1-a , fullthrottle95 , jreger , JSoko , Roostertail , Russo2 , Smihshooter , Ted94 , The Frankster , TwoSpeed
My Rolling Rebuild. Ridgerunner 1973-1991 Ford F150
678 November 6th, 2012 11:35 PM
M5ODR2 rebuild? F150GT Garage Talk: Engine & Drivetrain 20 May 20th, 2012 09:38 PM
M5OD-R2 Rebuild Russo2 1973-1991 Ford F150
2 March 27th, 2012 05:00 PM
302 rebuild whitesleeper Garage Talk: Engine & Drivetrain 9 January 7th, 2012 12:30 AM
mini rebuild abervintageman42 Garage Talk: Towing & Hauling 8 December 14th, 2009 03:14 AM
motor , rebuild
