Quantcast Codes - Ford Truck Club Forum
Old May 4th, 2013, 11:23 PM
Default Codes
Twisted was driving the truck today and told me that the CEL had intermittently come on. So I ran a KOEO test and this is what popped up.
121 closed throttle TPS voltage high or low
Ok, I may need a new TPS.
172 Engine lean right bank (p/s) I have one O2 sensor so how can it tell one bank from another?
327 DPFE or PFE circuit voltage below .02 volts
Can't help but wonder if 327 is related to the 172. Not sure. I've had problems with the DPFE code before back when I went to Texas last November. Back then I replaced the EGR valve and the EVR sensor on top but not the DPFE. IIRC, its the vac solenoid on the d/s bank of the engine, right?
Any suggestions?
Old May 5th, 2013, 09:16 AM
I think 172 is because you have only 1 O2 sensor.
Old May 5th, 2013, 10:16 AM
http://www.troublecodes.net/Ford/
(R) = Engine Running test (M) = Memory code (O)=Key On Engine Off test
172
(R,M)
Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
121
(O,R,M)
Throttle Position (TP) sensor out of range - TPS
327
(O,R,M)
EGR feedback signal is/was low - EVR or PFE
Old May 5th, 2013, 10:43 AM
Maybe, but that really doesn't make sense to me. With the factory exhaust the O2 was in a little cross over tube just before the Y in the pipe. Now it is plumbed into the P/S header collector. The codes states that it is a lean condition for the P/S of the engine. How does it differentiate the exhaust gasses from one side of the engine to the other when the exhaust was stock, Especially now that it has no idea what the D/S of the engine is doing? Is the EEC capable of some sort of pulse timing the exhaust flow in measuring O2 in the exhaust from bank to bank? If that's the case I need to replumb the O2 sensor in the X pipe.
There must be another way the EEC is calculating this or the code explanation from oldfuelinjection is inaccurate. Right now I think that I have to assume the whole system is lean, or at least when the CEL pops up. I going to run a KOER and CBST later today and see what I get. I didn't last night due to the noise of it all and it being late.
Old May 5th, 2013, 09:18 PM
I've cleared the codes and will see if they return. If not ill rerun a full string of tests next weekend. As of right now nothing is showing but system pass.
Old May 5th, 2013, 09:20 PM
IIRC on my 88, which retained Factory Emissions, my O2 sensor was screwed into a bung that was welded in between the Forks of the Y so both sides were read.
Old May 5th, 2013, 09:35 PM
Yup that's how the 94 was setup stock. The question is, as far as the O2 and the 171 code is concerned, how does a single O2 differentiate the difference between one bank and the other? I think there's no way and glc's description of the code makes more sense. 1 O2 means the entire engine was lean at one time. The only thing I'm concerned with now is the TPS and DPFE codes. I should see something next weekend as I will have a little bit of traveling again next weekend. About 300 miles worth. If there's a problem it will likely rear its ugly head. I've got roadside so no worries.
Afterthought: I'm kind of wondering if I have a bad ground somewhere. Hmmmmm
Old May 6th, 2013, 02:06 AM
Where you have your sensor plumbed in, you really are only measuring one side. The EEC of course thinks it's a single.
Old May 6th, 2013, 02:14 PM
I understand that but wouldn't it still measure the o2/exhaust levels the same as if it we're stock? I mean, its kinda obvious, to me anyway, that with a single O2 sensor stock that it would in no way be able to determine a lean condition from one bank to the other. The entire engine would have to of been lean at one instance.
Old May 6th, 2013, 02:49 PM
Idk, I could be wrong.
adoporto , ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , brick13 , glc , Hazzardousmat , jheat , joe250 , JSoko , lostcause , michaelsnodgrass18 , Moore1991bronco , nine5flareside , Russo2 , The Frankster
codes/no codes joe250 1987-1991 Ford F250 | F350
3 March 23rd, 2013 10:32 AM
Codes! JCruz 1973-1991 Ford F150
3 January 29th, 2013 10:50 PM
Rear axle codes The Frankster 1992-1996 Ford F150
7 June 24th, 2012 07:24 PM
Door tag codes. Russo2 Garage Talk: Shop Class 101 2 February 28th, 2012 09:54 PM
Trans codes Klitch 1997-2003 Ford F150
3 October 20th, 2011 03:27 PM
codes
