Quantcast 1995 F150 Loss of Power - Ford Truck Club Forum
Old October 18th, 2013, 05:44 PM
Sidecar's Avatar
Sidecar Sidecar is offline
Default 1995 F150 Loss of Power
We have a 1995 F-150 with a 302 engine. Runs great in town, has plenty of power. When we take it out on the highway it runs fine for about 60 miles then the "check engine" light comes on and we lose power. If I give it full throttle it surges ahead like it is in passing gear. We have replaced the throttle sensor. Engine does not use any oil. If we let it set for 15 or 20 minutes it runs fine for about another 40 or 50 miles and starts the same problem. It is definitely running out of fuel.
Old October 18th, 2013, 06:41 PM
You need to read the codes if the CEL is coming on.
http://oldfuelinjection.com/?p=13
Old October 18th, 2013, 07:15 PM
Sidecar's Avatar
The code said we need to replace the Thottle Sensor and we did.
Old October 18th, 2013, 09:33 PM
Codes do not tell you what to replace, they tell you what circuit is faulty. You still have to do manual mechanical, voltage, and resistance checks.
Have you cleared the codes and seen if they come back? What is the exact code or codes?
Old October 18th, 2013, 09:58 PM
Sidecar's Avatar
Default Sidcar
If I remember right, the code was 167, the voltage was good (not high or low), the throttle sensor was replaced and did not make any difference. We use this to drive around town and it is fine. The only time it gives us any trouble is when we take it out on the highway. Both pumps check out well, front and rear. We're still searching. Thanks for your reply.
Old October 19th, 2013, 01:28 AM
Are you sure your cat isn't clogged and overheating?
Have you cleared the code and seen if it comes back?
Old October 19th, 2013, 08:33 PM
Sidecar's Avatar
Yes we have cleared the codes, took another reading today everything is good. We used the truck today RUNS GREAT!!
ASwaff400 , bikertrash3531 , blueford , f1504x4driver , funkman , glc , JSoko , Matthew , Sidecar , The Frankster , waterguy73 , yahnke
stumped and at a loss..help ford f150 chrisandkc 1992-1996 Ford F150
11 November 27th, 2013 01:03 PM
1986 F150 power loss timok 1973-1991 Ford F150
2 October 31st, 2013 12:19 PM
Need help with intermittent engine sputter and loss of power ps4bob 1948-1986 Ford F250 | F350
5 September 26th, 2013 03:07 PM
1999 f350 powerstroke power loss tcasebeer 1999-2007 Ford F250 | F350
10 July 8th, 2011 09:18 AM
0 February 11th, 2011 07:33 PM
1995 , f150 , loss , power
