Quantcast 1960 Ford 4x4 - Page 4 - Ford Truck Club Forum
Old November 19th, 2013, 07:38 PM
carbineone's Avatar
carbineone carbineone is offline
Heres a little update. I put a new set of points, plugs and rotor in. They came with the truck in the Glovebox. Also put a new cap and wires. Put a kit in the Carb. Got the brakes bled and up and going. Got the Hydrauliic Clutch working.
I ran it first off a temporary tank so the old Gasoline from the Tank could all run out in a container. Put fresh gas in the tank after it went dry. And also a new fuel filter.
Checked all the air pressure. Took it for about a ten miles drive. Ran really nice. Drove decent too. Heater works, Horn works. Wipers work, Headlights and tailight work. Only things I have found that I need to figure out yet is why the Blinkers and brake lights are not working. Could just be a fuse hopefully that is knocking them both out together..
I greased all the zerks in the steering and driveline. I need to check all the grease levels in the Differentials and the Tranny/ Transfer case. Do all those just use the same 80 90 gear oil? Oil and filter change yet and that will be it till I decide whether to sell it or keep it..
Also what goes in the front axle out at the ends.. Looks like there is a plug on each side. Does 80 90 in those balls too?
Also removed the Plow and here is a pic without it on. The frame is not cut thank God.. But the Bumper is gone now. How hard is that going to be to find? Will other years work? The headlight bezels are gone too. May be kinda hard to find those also. Thanks
  #32
Old November 19th, 2013, 09:43 PM
Lmctruck.com and National Parts Depot would be your best bet for a bumper and what not. NPD would probably be your best bet as LMC is a bit pricey and Customer Service isn't as good as it used to be. Looks a bunch better without the plow!!
  #33
Old November 20th, 2013, 10:20 AM
carbineone's Avatar
Thanks, The Depot one does not list much for the 59 60 I could find. Seems they skip that Era..I like the Idea of the LMC place as it is just south of me in Kansas..
  #34
Old November 20th, 2013, 11:01 AM
I use 80w90 in old Trucks
here are some FORD specific links
try www.macsautoparts.com/hz for old FORD parts
and www.dennis-carpenter.com for hard to find FORD weather stripping
  #35
Old November 21st, 2013, 04:58 PM
carbineone's Avatar
I like this truck, but I think it is going to go, The main reason is I think it is going to be even worse on mileage than I thought. I could live with maybe 12 MPG for a occasional drive. But I swear I put 3 gallons in and it ran out in about 16 miles of Highway and gravel road driving..LOL
I have a 1981 F100 Flareside with a manual tranny and a 300 six. One has to go and I think it makes more sense to keep the 81. Alot more sensible driver all around I think. Really would like to fix the 60 up though..
If you can talk me into keeping the 60 with good reasons. I sure would like that
Thanks
  #36
Old November 21st, 2013, 06:26 PM
if I lived closer I'd take I off your hands
the 3 gals you added to the empty tank gave you probably less than a gallon to run on
65custom (February 29th, 2016)
  #37
Old January 22nd, 2019, 10:43 PM
ElGringo's Avatar
ElGringo ElGringo is offline
Default Try Rubber The Right Way
Can Check Rubber the Right Way also. I have found them to be cheaper than Mac's & Carpenter for the same products. Good people. www.RubberTheRightWay.com
65custom , bikertrash3531 , Booba5185 , carbineone , ElGringo , glc , harrison28 , jonny99 , JSoko , supertrainguy , vinnyboy2409
installing 1993 f350 instrument cluster in a 1960 f100 willd 1948-1983 Ford F100
7 September 20th, 2012 12:56 PM
1960 F100 from Brazil vmazzoni New Member Introductions 17 July 11th, 2012 03:31 AM
Art Morrison 3G 1960 Corvette TheSmokingTire The Smoking Tire 0 October 4th, 2011 05:54 AM
1957-1960 Ford F-Series Trucks & Panels calinleir FORD F-100 | F-150 SERIES 0 December 19th, 2010 09:40 PM
1960 , 4x4 , ford
