Quantcast EEC/ECM/PCM ??? Location - Ford Truck Club Forum
Old January 1st, 2014, 10:31 PM
adoporto's Avatar
adoporto adoporto is offline
Exclamation EEC/ECM/PCM ??? Location
Ok I have searched this site as far as I could and maybe I'm just not doing something right. Where can I find info on the computer and how to replace it. I looked under forums, searched under forums, tech articles, and garage talk under engine, and nothing did I miss it somewhere?
Has anyone done a write up on what EEC/ECM/PCM what is the difference if any and what do they mean?
I have finally decided to replace the CPU after working and trying to get codes from truck and have come empty handed.
Can someone please lead me in the right direction.
Thanks
1992 F150 XLT 4x4- 1995 donor motor 5.0/302
Mods: K & N intake, MSD ignition, Reroute PCV, Rubber Vacuum System, and Remote Start
Soon to come: Long tube Headman Headers
Old January 1st, 2014, 10:47 PM
Your PCM is on the far driver side firewall, down by the fender on the driver side. PCM is Powertrain Control Module, meaning it controls the engine and transmission. ECM is Engine Control Module, meaning it only controls the engine. EEC is Electronic Engine Control, which I think is the same as ECM.
Old January 8th, 2014, 09:09 AM
Lostin90s's Avatar
you need one for yout trucks engine,trans combo . ie. 302 with e4od ,
adoporto , ASwaff400 , bikertrash3531 , Booba5185 , Bulldog74 , F150GT , glc , judd94 , KD-DET , lanejesse85 , Lostin90s , Old red and white , Russo2 , The Frankster
1996 460 crank posistioning sensor location technovike 1992-1997 Ford F250 | F350
0 November 14th, 2012 01:53 PM
pcv location jonavikl 2004-2008 Ford F150
6 October 2nd, 2012 06:27 PM
2011 F350 Super-Duty Satellite Audio Module Location quik-shots 2011-2016 Ford F250 | F350
0 June 6th, 2011 11:28 PM
eec or ecm or pcm , location
