July 29th, 2010, 11:35 AM
Feedback Score: 0 reviews
thanks webmaster. I planed on fixing the gas leak just because i dont want to waste $$ on gas. i got work so sofar i was only able to drop the skid plate. When I get home I will check the two clamps for the fuel tube thingy. Theres an upper and lower one and they both leak. After that I'll add some more gas, 87 instead of 89, and try starting. if it don't, ill disconnect the maf as you said and I will let you know what goes on from there. When the truck starts I hear a whine so I know the fuel pump kicks on but i am not sure if it is weak. I read somewhere the symptoms of a bad fuel pump: "a bad fuel pump will cause fuel injection problems. When this happens, the truck may sputter and stall at start up. After the vehicle does start, it may act as if it is about to stall, while running, because it can not get enough fuel." I also read some where that some times when the fuel filter gets dirty, something overrides it and allows more gas to come threw. Allowing dirt and impurities getting to the engine. The truck was sitting for a little bit before I bought it so there could be some grime in the tank. Just another thought.
