Quantcast Radiator hose/pipe??? - Ford Truck Club Forum
Old September 11th, 2014, 03:23 PM
adoporto's Avatar
adoporto adoporto is offline
Default Radiator hose/pipe???
There is a rubber hose that comes off the neck of radiator just below the cap, it is rubber then switches to a metal pipe (going across shroud) and back to rubber towards the engine, where it is leaking. I have looked high and low for a replacement and have come up with nothing. LMC the internet, is there a specific name for this hose/pipe?
Thanks
1992 F150 XLT 4x4- 1995 donor motor 5.0/302
Mods: K & N intake, MSD ignition, Reroute PCV, Rubber Vacuum System, and Remote Start
Soon to come: Long tube Headman Headers
Old September 11th, 2014, 04:54 PM
Images: 616
Liked 170 Times in 152 Posts
can you post a photo
Old September 15th, 2014, 10:24 PM
adoporto's Avatar
Default Radiator Hose/Pipe Pics
Yes Sir, here you go.
Name:	Truck Hose Pipe.jpg
ID:	1068   Click image for larger version
Name:	Hole in Hose.jpg
Old September 16th, 2014, 07:34 AM
looks like it goes into the throttle body, does it?
post a pic up close of where the leak is/throttle body
Old September 16th, 2014, 04:47 PM
adoporto's Avatar
Default More Pics
Up close pics, I would just replace hose but it is attached to metal pipe via compression type fitting.
ID:	1070   Click image for larger version
Old September 17th, 2014, 06:48 AM
that same hose leaked on my 302 before i did the swap. the steel pipe its attached to rusted through. if you live in a warm climate(dont have to worry about freezing) you can bypass it all together. i simply cut the bad portion of hose out, removed the hose on the bottom of the throttle body, and hooked them together... that system is intended to warm up the TB to keep it from freezing in cold climates.
Old September 17th, 2014, 12:28 PM
adoporto's Avatar
We have extremely high temps 110+ and low temps too. -0 below. I guess it would be wise not to bypass. As a temporary fix until I can find the original part, I'm sure running a full rubber hose wouldn't hurt. I'm thinking they went from rubber to metal is because of its location and it could possibly get pinched or cut. Thanks for the info.
adoporto , ASwaff400 , barrett_s , chesster51 , glc , JSoko , mike , MR_Pete , mtume224 , NorthernCali4.9 , Palindrome , pete59edsel , Russo2 , skatebowd , The Frankster
Top Heater Hose The Frankster 1992-1996 Ford F150
6 September 21st, 2013 05:55 PM
HF Pipe Bender Raleigh Garage Talk: The Tool Depot™ 4 January 28th, 2012 09:56 PM
exhaust H PIPE JSoko Garage Talk: Engine & Drivetrain 0 January 17th, 2012 11:00 AM
How to Repair a Car Heater Hose JSoko Garage Talk: Shop Class 101 0 May 28th, 2011 10:32 AM
Hose Candy Gearz Gearz 0 March 23rd, 2011 03:32 PM
hose or pipe , radiator
