Quantcast How to Repair a Car Heater Hose - Ford Truck Club Forum
Old May 28th, 2011, 10:32 AM
Images: 621
Liked 170 Times in 152 Posts
Exclamation How to Repair a Car Heater Hose
you're driving along running just a bit late for an appointment when steam starts belching up through the edges of the hood. Your car has just blown a heater hose and the coolant is vaporizing as it drains onto the hot engine. Well, we can't make you feel any better about what just happened, but we can help you get back on the road in a reasonable amount of time. If your car is more than 6 years old, no doubt your radiator and heater hoses have seen better days.A heater hose repair kit is great insurance against roadside disaster
Next time you're in the auto supply store, pick up a kit containing a heater hose coupling and a pair of clamps. The kit doesn't cost much and is a good insurance policy. Just be sure you also carry a flashlight, a pocketknife and a set of screwdrivers (essential tools to always have on board)
A leaking heater hose will stop your car dead in it's tracks, but with a basic repair kit you can fix the hose yourself, even out in the middle of nowhere, and be driving again in an hour.
Emergency heater hose repair
Open your hood and let everything cool down
Don't mess with the radiator cap or anything yet! Don't touch anything until you can do so comfortably. You could get a serious burn. You might have to wait as long as 45 minutes. As the engine cools, look for splits or tears in the hoses. The telltale signs of a blown hose will be coolant splashed over the engine and under the hood. This alone doesn't mean you have a blown hose, however. It could be a faulty thermostat that caused the radiator cap to release. If the cap has a pressure-release flap that's released, your engine may have only overheated, but if the cap is intact and you can see a leak in the heater hose, you'll be able to fix it. Once the engine is cool, remove the radiator cap. Put the cap back on after the fix.
Look for a leak along the length of your heater hose
Carefully examine the hose from the water pump back to the heater core inlet and outlet near the firewall (backside of the engine compartment).
Cut out the bad section of hose
The leak may be at a fitting on the water pump or even at the heater core. If this is the case, you won't need to use the coupling; just cut the bad end off the hose, stretch the hose and reclamp it to the fitting. If the leak is along the hose, cut it at the leak and remove the bad section.
Push the hose firmly onto the coupling
Apply coolant to the coupling as a lubricant. Insert one end and tighten the clamp on it. Then slip the second clamp over the hose and push the other end of the coupling into the hose.
Hose coupling
Hose couplings come in several sizes. Check your hose before buying
Tighten the clamps
Make sure the hose is slipped onto the coupling and tighten both clamps. Don't cowboy the hoses; they may be fragile and in need of replacement. Add water to your reservoir or radiator, or drive (no longer than 10 minutes!) to the nearest place you can get coolant. This fix isn't permanent, so make an appointment to have your hoses and coolant checked.
4calico , HawaiianF150 , JSoko , nine5flareside , Rich Hoffman
How to Diagnose and Repair a Broken Auto Light Socket JSoko Garage Talk: Shop Class 101 0 May 28th, 2011 10:24 AM
Hose Candy Gearz Gearz 0 March 23rd, 2011 03:32 PM
BadShoe Productions now has digital downloads of the How To Repair video titles BADSHOE BADSHOE Productions 0 March 12th, 2011 03:16 PM
2004 Fx4 heater pete59edsel 2004-2008 Ford F150
15 February 19th, 2011 09:26 AM
Front Brake Repair 97-03 F150 DIXIE FIX Garage Talk: Shop Class 101 2 August 28th, 2010 04:27 PM
car , heater , hose , repair
