Quantcast squeeky steering wheel and tire pressures - Ford Truck Club Forum
Old November 27th, 2019, 07:07 PM
mr.c's Avatar
mr.c mr.c is offline
Default squeeky steering wheel and tire pressures
2000 F250.....my steering wheel 'squeaks' when I'm going slow. Left or right..doesn't matter. Fluid is good. Any ideas. Also, what should my tire pressures be? Got 285/75 R16 on her. Sticker on door jam says 65 front....80 rear. WOW, but then I've never had a truck this heavy before. Should I put more in when I'm towing? Thanks
Old November 28th, 2019, 12:18 AM
What load range are the tires? Post the exact brand and model, along with sidewall data that indicates max load and pressure.
The squeak may be a dry u-joint in the steering shaft.
glc , harrison28 , mr.c
94-96 steering wheel replacement bikertrash3531 1992-1996 Ford F150
1 April 21st, 2013 08:04 AM
Steering wheel MOD TFH Kane 1997-2003 Ford F150
2 March 21st, 2012 09:29 AM
steering wheel swap? ASwaff400 1992-1996 Ford F150
2 January 10th, 2010 11:02 PM
Tire & Wheel Calculator JSoko Garage Talk: Wheels & Tires 20 July 20th, 2009 04:23 AM
pressures , squeeky , steering , tire , wheel
