Quantcast Engine Missing on acceleration or when "punching it" - Ford Truck Club Forum
Old March 9th, 2016, 03:17 AM
adoporto's Avatar
adoporto adoporto is offline
Default Engine Missing on acceleration or when "punching it"
I have a 08' F150 5.4 L King Ranch, when I'm at a stop sign and take off or even at a rolling start if I accelerate quickly or "punch it" I get some hesitation or a miss? Any ideas where to start? Completely new to this vehicle purchased it about 1 year ago. All I have done are the regular oil changes and air filter changes so far.
1992 F150 XLT 4x4- 1995 donor motor 5.0/302
Mods: K & N intake, MSD ignition, Reroute PCV, Rubber Vacuum System, and Remote Start
Soon to come: Long tube Headman Headers
Old March 9th, 2016, 08:42 AM
Images: 620
Liked 182 Times in 164 Posts
how about that check engine light ?
I had a similar issue
turned out to be the crankshaft position sensor
Old March 9th, 2016, 11:43 AM
Liked 96 Times in 93 Posts
How many miles on it? If over 60k, change the spark plugs. Put a bottle of Techron in the gas.
Old March 20th, 2016, 02:41 PM
pete59edsel's Avatar
Images: 101
Liked 6 Times in 6 Posts
Yeah first thing check codes, other then that your tossing good money after bad. I could tell ya its because of your gas, i could tell you cops may be going out, i could tell ya its cause your sock has a hole in it. Good luck.
Old April 28th, 2016, 09:30 PM
adoporto's Avatar
Exclamation
It has 129k on it, I bought it and it had 110k. The only thing I have done is regular oil and air filter changes.
As for the check engine lights, nothing has come on. I did the system check and all is good. Since my last post I now have a radiator leak of some kind and when driving I also hear a fan like noise and it increases as I give it more throttle. When it rains it pours!!!!
Old May 1st, 2016, 07:09 PM
adoporto's Avatar
Exclamation Reduced Engine Power
I now got a message from the dash "reduced engine power"
Old May 1st, 2016, 07:44 PM
adoporto's Avatar
Exclamation Checking Codes?
I may have a two part problem here, one a radiator leak/hose which I will have to dig some more to find where it is actually coming from. I think this may be related to the Reduced Engine Power issue
Two the hesitation sound a lot like VCT solenoid that Pete wrote up a topic on.
This may sound like a stupid question or statement, I have never pulled codes from any vehicle which sounds pretty basic. Do you have to buy an expensive gadget or just take to shop? I've seen guys talk about using a paper clip jumper on older fords(my 1992). I'm new to the 2008's.
Thanks
Old May 2nd, 2016, 06:02 AM
Images: 620
don't know if this has anything to do with your leak
but see this
http://www.fordtruckclub.net/forum/s...ead.php?t=1541
Old May 2nd, 2016, 10:32 AM
All you need is a OBD2 code reader, they can be bought online for $20 - most parts stores offer free code reading.
Amazon.com: Autel MaxiScan MS309 CAN OBD-II Diagnostic Code Scanner: Automotive Amazon.com: Autel MaxiScan MS309 CAN OBD-II Diagnostic Code Scanner: Automotive
adoporto , alextal07 , glc , harrison28 , JSoko , Klitch , MR_Pete , Ozzie , pete59edsel , Stone F150 , tjlacey
Rewiring a Ford EEC IV "speed density" harness to a "mass air" harness BADSHOE BADSHOE Productions 0 January 12th, 2014 11:18 AM
1500 HP EVOMS "Mayhem" 997 Turbo Rolling Half Mile TheSmokingTire The Smoking Tire 0 January 13th, 2013 11:16 AM
Boxer Hector "Macho" Camacho remains on life support BigBlue79 General Discussion
2 November 24th, 2012 12:41 PM
37" Toyo Open Country Tires Installed On 22" Rims Part 2 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
acceleration , engine , missing , punching it
