Quantcast next small project - Page 12 - Ford Truck Club Forum
Old October 23rd, 2018, 03:58 PM
Without advance. It's just a plain 2 wire points distributor. My grandfather has a timing light. I'll try and do it the right way to make sure I don't exceed the 16 BTDC. Thanks for the help GLC.
  #112
Old October 23rd, 2018, 04:55 PM
Liked 71 Times in 68 Posts
Hmm - without vacuum advance, what does it have? Mechanical advance only or is there some computer control involved?
  #113
Old October 25th, 2018, 03:05 PM
As far as I know there isn't anything,..unless it's mechanical and built in to the distributor. The only wiring is a black and a purple that go to the ignition coil.
  #114
Old November 29th, 2018, 02:10 PM
Well,...I've been fighting with the high pressure pump in the tank over fueling through the regulator after driving it for a while. I'm over it. Picked up a fuel tank and sending unit for a 1984 F150. Also grabbed a roll of 3/8" fuel line. Gonna just go with the old school mechanical pump on the motor.
  #115
Old November 30th, 2018, 09:50 AM
Got the old tank drained and dropped last night. New tank and sending unit are installed. Tonight I'll demo the old fuel lines and the regulator. Finish running new fuel line to the mechanical pump. Still need to go through my wiring diagram to see which wire is the fuel gauge. Should be running like a champ this evening.
  #116
Old December 14th, 2018, 08:21 AM
Images: 616
Liked 170 Times in 152 Posts
thanks to George I can get into and see your thread
keep up the good work and keep us posted
did you get it running?
  #117
Old December 14th, 2018, 09:41 AM
Yes sir I did. I had to change the carb out. The Holley 600 marine carb was giving me the high idle issues. When it was warm, the throttle wouldn't return all the way, even with 3 springs. I put a Holley 750 double pumper on it that my grandfather had laying around. Runs like a champ now. I use it whenever I'm not at work. I wired up the new sending unit in the new tank. I think the 84 sending unit works backwards from the 91. When I filled the tank, it went all the way to E on the gauge. I'll just have to remember "E" means "Enough" and "F" means "Find a gas station".
  #118
Old December 14th, 2018, 10:26 AM
Images: 616
did changing the wires around do anything
  #119
Old December 14th, 2018, 11:01 AM
I didn't change them around because one of the 2 studs on the sending unit is a ground. Maybe I should try it though. Worst it can do is not work.
  #120
Old December 15th, 2018, 09:09 AM
Images: 616
E to F will work, if indeed it does
(View-All Members who have read this thread : 40
77carolina , axcell , bdscaocap , beefman , Bighorse , bigpapahh , blbokeb , Booba5185 , dxmbcaocap24h , F100Chief , FOFO F-150 , ford40 , FordGuy1959 , Found_On_Richies_Driveway , FXRS , glc , gwfan , Hamilton Fordy , Hanknguyen , harrison28 , HATCH630 , Inside Man , IrishKRO , JSoko , Klitch , Lmadsen , MAmalfa , MarkV , mefreeman , Monkeyfinger , polargeek , Punisher1964 , ralph2854 , Shanevc , skatebowd , Steve1983 , The Bake , vietphanmem20588 , vjsimone , Yankee
Several small problems The Frankster 1992-1996 Ford F150
7 January 26th, 2014 10:54 PM
4-8-13 small update nflfreak43 1992-1996 Ford F150
3 April 8th, 2013 09:53 PM
How-To Rebuild the Top End of a Chevy 350 V8 Small Block Engine MOTORZ TV MOTORZ TV 1 May 5th, 2012 11:21 AM
How-To Tear Down a Chevy 350 V8 Small Block Engine MOTORZ TV MOTORZ TV 0 September 23rd, 2011 02:50 PM
Truck U: Small Engine TRUCK U TRUCK U 0 July 26th, 2010 05:26 PM
project , small
