Quantcast 98 f150 v6 vacuum diagram - Ford Truck Club Forum
Old April 27th, 2015, 07:10 PM
nmorse1234's Avatar
nmorse1234 nmorse1234 is offline
Default 98 f150 v6 vacuum diagram
Hello does anyone have a diagram of the vacuum lines. I.e the line from the PCV goes to? Does that lin run straight to the idle air intake sensor or does it go to multiple spots? I think the line that goes from the idle air intake sensor and down the left side of the motor towards the PCV valve has a leak. Was going to run a line on the outside so I don't have to take off anything. but want to make sure that the line is a direct line first.
Old April 28th, 2015, 12:48 AM
The PCV valve should have a large vacuum line going from it direct to a vacuum port on the intake manifold.
Old November 7th, 2016, 04:09 PM
Rachel's Avatar
Rachel Rachel is offline
Unhappy
ur pcv valve should run from the valve to the top of ur manafold but mine also runs to the back of my engine. I have found a splitter that runs from the pcv valve. I also have a 4.2 but is a 97. I found that my problem was the pcv valve was sitting on top of where it was supposed to be and had two vacuum hoses running to it is that normal do u know? I cant find a diagram of the hoses either.
glc , harrison28 , JSoko , Klitch , MADV79 , nmorse1234 , Rachel , skatebowd , steve95
vacuum diagram craig 1973-1991 Ford F150
0 February 6th, 2015 05:28 AM
9 July 13th, 2013 12:25 PM
1995 F150 -Vacuum System Delete nine5flareside 1992-1996 Ford F150
17 September 12th, 2012 09:30 AM
1986 F150 4x4 300 I6 vacuum diagrams BigBlue79 1973-1991 Ford F150
0 April 3rd, 2012 09:53 PM
1985 F150 300 4.9L Vacuum Diagrams BigBlue79 1973-1991 Ford F150
4 February 2nd, 2012 10:49 PM
diagram , f150 , vacuum
