Quantcast 1991 f150 5.0 efi - Ford Truck Club Forum
Old October 8th, 2012, 09:56 PM
DON CHILDS's Avatar
DON CHILDS DON CHILDS is offline
Default 1991 f150 5.0 efi
What causes engine to idle too fast 1700 RPMs?
Old October 8th, 2012, 10:05 PM
At all times? Just at start up? In gear? In park? A few more specifics might help us narrow down the cause. Don't want to throw a hundred different things at you and then have you hope one of them will eventually work.
Old October 8th, 2012, 10:13 PM
DON CHILDS's Avatar
It idles high at all times. Have checked and cleaned IAC.
Old October 8th, 2012, 10:26 PM
I would take a look at the Throttle Position sensor. Here is a link that describes it better than i can.
http://oldfuelinjection.com/?p=30
Old October 9th, 2012, 09:41 AM
How did you check the IAC? What happens if you unplug the IAC while the truck is running? Have you checked for vacuum leaks? If so, how did you check?
After all that, I'd check the TPS voltage as well, should be at .97v.
Old October 9th, 2012, 10:38 PM
DON CHILDS's Avatar
I checked the iac for resistance with a voltmeter and it checked good according to haynes manual. The truck still runs at high idle when the iac is unplugged. I just checked for vacuum leaks by hand, have not sprayed any flammable material on there. We are in the process of trying to do an sti but are learning as we go. The check engine light is not on.
Old October 9th, 2012, 10:46 PM
Run the codes anyway, It's simple to do with your truck being obdI. I'm not sure if there is a thread for it on here yet or not? I could make one tomorrow I guess.
I also have yet to see a good way for checking the IAC besides unplugging it and seeing what the truck does. IIRC mine runs at a high idle for a little then dies.
Old October 9th, 2012, 10:59 PM
I did a thread for OBD-1, lemme grab it.
Old October 9th, 2012, 11:02 PM
http://www.fordtruckclub.net/forum/s...ead.php?t=6720
Old October 9th, 2012, 11:07 PM
I would like to add to that thread soon if that's okay with you blue, with how I do the codes and a video of actually pulling codes.
(View-All Members who have read this thread : 22
87F150Jess , ASwaff400 , barrett_s , benyonder , BigBlue79 , bikertrash3531 , Booba5185 , digger3164 , DON CHILDS , DoubleDee , Dougy1964 , emedlijn , FXRS , IrishKRO , JCruz , JSoko , nine5flareside , Pcbauer , Ridgerunner , Russo2 , scbill , TNT
9007 Headlight Bulb Conversion for 1987-1991 Trucks BigBlue79 Garage Talk: Shop Class 101 13 August 27th, 2012 07:42 PM
1991 4.0 code 85 Klitch 1989-1992 Ford Ranger
0 March 20th, 2012 11:52 PM
Girl missing since 1991 found alive Bates88 General Discussion
4 August 27th, 2009 08:21 PM
1991 , efi , f150
