Quantcast Need a new wheel and an alignment - Page 2 - Ford Truck Club Forum
Old September 20th, 2012, 06:30 PM
yes, the St Ranger makes a good spare
good luck in your search
Old September 20th, 2012, 08:23 PM
DoubleDee's Avatar
Images: 669
Got good news and bad/worse news. The good doesn't offset the bad. Good news, I got a new wheel. Has the TPMS as well. Worse news... let me get my notes.
1. Needed a new clamp for the TPMS. 55 bucks.
2. More damage that I hoped for - the lower A arm rear mount is bent backwards, and the bushing has been pushed inboard. (Pics to follow shortly)
3. When I kissed the curb, it pushed the wheel in so hard, that it hit the lower ball joint bolt and scratched the the wheel. (not so much bad news, but now I know where it came from.)
4. I'm gonna need more than just an alignment. Might have to get that bracket tapped straight, if that wasn't a tear in the metal I saw.
So, with the lower A arm rear bracket bent back and in, I know why the truck pulls to the right, and have to hold constant counter steer pressure.
Someone want to buy a slightly used F150, has 36100 on the ODO... Steering is a little cockeyed... Has a new wheel, CB, $1500 sound system, front seat covers, tow mirrors & package, weathertech floor liners in the front, FX headlights, Gotts mod, 160 amp alt, with the stock 110, small truck/tool box, OEM fender flares...
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
Old September 20th, 2012, 08:30 PM
its not that bad
I thought the A-arm was aluminum, may be the upper is
Old September 20th, 2012, 08:31 PM
DoubleDee's Avatar
Images: 669
The lower i think is aluminum. But the rear bracket is bent backwards... I don't know if I'll need a new lower a arm... I think the upper is still the steel tube/rod.
Double(. Y .)Dee
SSG, TXARNG
VIN Decoder
Big 3 Upgrade
Seat Removal
Old September 20th, 2012, 09:19 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
A $400 fix is cheaper than a new truck payment! All Im saying!
Black Sheep of FTC
Old September 21st, 2012, 06:18 AM
the reason I mentioned aluminum, is that it may be cracked
cast aluminum, may bend a little but usually breaks or cracks
get the New Truck, RAPTOR
  #17
Old September 21st, 2012, 01:35 PM
DoubleDee's Avatar
Images: 669
Ha, As much as I would like a Raptor, I don't plan on it.
Stealership or garage/mechanic/body shop?
Double(. Y .)Dee
SSG, TXARNG
VIN Decoder
Big 3 Upgrade
Seat Removal
  #18
Old September 21st, 2012, 03:03 PM
see'n how your Trucks has been faithful
looks like its time to research a independent mechanic, one that has a good reputation, someone that you feel good about as it may not be the last time you may need his services
A good mechanic will be your Trucks best friend, his labor rate should be lower than Ford and if you request preminum parts you should still save money
keep in mind that he makes a small profit on parts, so taking him parts that you buy for him to install may leave a bad taste in his mouth
  #19
Old September 21st, 2012, 06:39 PM
sounds like an excuse to do an SAS!
Old September 21st, 2012, 09:13 PM
great idea,or as they say on American Chopper , good Idera
ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , catmechanic07 , DoubleDee , JerryR , JSoko , mr wu , ncranchero , Ridgerunner , Russo2 , Scf150lover , skatebowd , The Frankster
Tools for Home Wheel Alignment JSoko Garage Talk: The Tool Depot™ 0 February 23rd, 2012 09:29 AM
Alignment bushings Russo2 Garage Talk: Brakes & Suspension 3 May 8th, 2011 11:20 PM
Alignment Cam Kit JSoko Garage Talk: The Tool Depot™ 1 July 18th, 2009 10:28 PM
alignment , wheel
