Quantcast Michelin Recall - Ford Truck Club Forum
Old January 12th, 2014, 09:41 AM
Exclamation Michelin Recall
I got a new set for the E250
there are other sizes affected other than what I list below; you have to check
but this is what I found about my LT225's
I heard about the recall on the local news
Here is the site info I found and the link
http://www.michelin.ca/safetyrecall
MICHELIN ISSUES SAFETY RECALL FOR COMMERCIAL LIGHT TRUCK TIRES
Michelin is recalling one version of a specific size of the Michelin LTX M/S tire. These tires are typically found on such vehicles as commercial light trucks, full-sized heavy duty vans, small RVs and some large pickup trucks.
The tires were produced between January 2010 and June 2012.
The tire version and size are:
Michelin LTX M/S LT 225/75R16 115/112R LRE
The tires were fitted as original equipment on some new vehicles and were also sold as new replacement tires.
Michelin is issuing the recall because a small number of the tires being recalled experienced tread loss and/or rapid air loss.
Michelin recommends removal of these tires as soon as possible. Owners of the affected tires should visit an authorized Michelin retail location as soon as possible to have the tires replaced at no charge.
To find out if a tire is affected by the recall:
Determine if it matches the information below:
Tire Description DOT Sequence DOT Production Periods (Inclusive)
Michelin LTX M/S LT 225/75R16 115/112R LRE B3JH AKEX 0210 – 2512
If the information on the sidewall of your tires does not match these identifiers, it is not part of the recall.
The following illustrations show the DOT information on a sample of the affected tires.
If you have any questions concerning the tire’s DOT information, please contact Michelin Consumer Care at 888-863-7777. Available 8am–8pm EST Monday–Friday; 8:30am–4:30pm EST Saturday–Sunday.
DOT sequence begins with B3JH AKEX ---
and ends with a date code (2-digit week and 2-digit year) between 0210 and 2512 inclusive.
additional info:
Michelin North America has announced a safety recall of approximately 1.3 million of its Michelin LTX M/S commercial light truck tires, sold in both the U.S. and Canada.
These tires are typically found on such vehicles as commercial light trucks, full-sized heavy-duty vans, small RVs and some large pickup trucks. Most of the tires were sold in the U.S with less than 100,000 sold in Canada.
No deaths or injuries have been reported in connection with the recalled tires.
This recall is being issued because an increasing number of tires are experiencing tread loss and/or rapid air loss.
The recalled tires were manufactured between January 2010 and June 2012.
The Department of Transportation date range that appears on the tire sidewall is represented by four numbers, with the first two digits denoting the week, and the last two digits representing the year.
The DOT range and product identifiers for the affected tires are:
Tire description, Michelin LTX M/S LT 225/75R16 115/112R LRE; DOT sequence, B3JH AKEX; DOT production, 0210-2512 (first two digits are week of the year and last two digits are the year).
The tires were fitted as original equipment on some new vehicles and were also sold as new replacement tires. Michelin stopped producing the tire in June 2012 as part of the company's normal process of refreshing its product lines.
Owners of the affected tires are advised to visit an authorized Michelin retail location as soon as possible to have the tires replaced at no charge.
For additional information on this recall, visit Michelin at www.michelin.ca/safetyrecall or call Michelin Consumer Care at 888-863-7777.
Old January 13th, 2014, 12:57 AM
Thumbs up
Old January 13th, 2014, 01:04 AM
I've always heard Michelin tires wear like iron. Its a shame this has happened. The last thing they need is a Ford/Firestone controversy.
Old January 13th, 2014, 09:58 AM
on the E250 my 1st set (factory Michelins replaced by dealer) got 91,000 mi / 7-1/2 years
I must say the the original factory tires always felt out of balance, the dealer did a 'Road Force' found the tires to be out of spec. and replaced all 4 shortly after I got the Van
I achieved that 91,000 mi by doing a 5 tire rotation as all 5 tires & wheels were the same
now the 5th tire which was the spare and never 'Road Forced' had no problems
the 2nd set (recall) had 17,000 mi / Dec. '13, and still looked like new
I keep the pressure correct and have a computer alignment done, the shop down the road just got a new machine
my front end joints all had plugs instead of zerk fittings, which I changed out and do a grease each tire rotation. The key to long life is grease and not adding so much that you split the boot.
My Dad would kick our ass if we did not clean the zerk fitting before greasing or split a boot
FYI: the 91,000 mi set had only one alignment done at 21,000 mi and wore perfect
NOTE: when the Michelins wore out I put a set of BF Goodrich Commercial tires on to save $300, I drove down the road and had to pull over to see if the tires were low on air or if they failed to install E load Range. The Van was swerving like it had a ton of bricks in the back. Went back and had the Michelins installed and it was a big difference. I'm staying with the Michelin LTX M&S II
Old January 14th, 2014, 08:46 AM
The Frankster's Avatar
Liked 12 Times in 9 Posts
Very odd for them to have a problem. They have been the best for years. Seems they are on top of it better than Firestone ever has been. If they had a set with the looks I want, that is what I'd buy. As for car/performance, I always had good luck with Radials/TA. I'm down to three types of rims I'm wanting and I'm thinking about Coker Redline's. My youngest sister got 90,000+ out of hers too J. She will run the Goodyears or Continentials for about 10k and then change to Michelins.
Old May 11th, 2014, 08:47 PM
pocus's Avatar
pocus pocus is offline
Thanks for sharing this info. I'm about to get one tomorrow good thing I read your post.
Old May 11th, 2014, 09:21 PM
my favorite tire is the Nitto Terra Grappler ive had great life and ride. on my second set in about 7 years
Old May 12th, 2014, 07:02 AM
I put a set on my '04
they are also a great rain tire
ASwaff400 , BigBlue79 , bikertrash3531 , catmechanic07 , glc , JSoko , larrhy2 , pocus , purple lady , skatebowd , The Frankster
'04 - '06 F150 Airbag recall JSoko 2004-2008 Ford F150
2 April 17th, 2011 07:23 AM
Ford to recall F-150 pickups over air bags BigT67 General Discussion
0 February 23rd, 2011 04:04 PM
Tylenol recall widens BigT67 General Discussion
0 July 9th, 2010 09:26 AM
GM to recall 1.3 million compact cars BigT67 General Discussion
2 March 2nd, 2010 12:57 PM
Ranger: 2009 recall BigT67 2001-2011 Ford Ranger
0 July 5th, 2009 06:18 PM
michelin , recall
