Quantcast 71 F600 Dump - Page 2 - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford's Not Listed
Old September 16th, 2011, 05:28 AM
Hay Klitch, well I resorted to calling the Souths authority on any and everything Kevin Thompson; it would'nt surprise me if his reputation has made it to the NorthWest
what you have Klitch is a 1971, F600, 2 axle, gas truck, engine size is 330 2V HD, made at the Louisville KY plant
he said you have a tough engine with forged crank due to the HD in the engine code
he can give more info if you take a pic or write down the info with the correct spacing per line from the plate rivited on the drivers door
he also said the 5th letter in your VIN is not a V but a U, he also belives you have a 2 speed axle
Old September 17th, 2011, 12:25 PM
you never did say what ya gave for the Truck ?
I hope the above info helps
Old September 17th, 2011, 02:19 PM
I paid 1200 for it, I feel that was a fair price considering it does need some work. Brakes #1 and hydraulic cyl leaks around the packing gland.
It is a 2spd rear axle, I've never driven one before, I haven't tried shifting it just yet.
Good to know what I've got that way its less hassle if I order parts for it down the road.
Old September 21st, 2011, 08:23 AM
Score: brake reservoir was very low, brakes work great!!!
Dump cylinder has me confused since there is no reservoir for it, 2 lines from the cylinder and pump. Makes me wonder where a guys suppose to fill from, and if 68wt hydraulic oil will work.
Old October 18th, 2011, 03:22 PM
hay Klitch, any updates or are you with for the winter to kill the Wasps
Old October 19th, 2011, 02:58 PM
Been busy playing with the girlyfriend. I Haven't found out the appropriate method for filling a power up / power down hydraulic cylinder. I did however lift the bed as far as possible, brace it, then remove the bleeder valve and bushing to use that as a fill point. which worked very well. the cylinder now has full function. Though I need to figure out the shaft seal (need to give the gf a rest) since it does leak significantly.
I'm looking for a rollback tarp to put on the overhead protector.
also looking at making a hook on the front and tailgate to use a come-along to pull the gate back up into place if I decide to use it as a open bed.
I've thrown some rust killer on the passenger floor boards. The carpet remnant thrown in there and original rubber floor mat got thrown out.
  #17
Old October 20th, 2011, 08:13 AM
yep them 'split tails' can boggle a man
what do you mean by rust killer ? thats a new one for me
  #18
Old October 20th, 2011, 03:37 PM
I just have trust issues
Rust killer, I usually use the rustoleum brand stuff so this can is what I usually use, but with a different logo for NAPA.
  #19
Old June 24th, 2012, 11:23 AM
any news on the F600 ???
  #20
Old June 26th, 2012, 01:57 AM
Used her the other day, "finished" the secondary driveway, will need another load of gravel to smooth over, I have pics of the secondary driveway to upload, may do that tomorrow. She works well enough for $1200 that I am happy! I usually tease the girlfriend that it may become my truck instead of stitches. :P
(View-All Members who have read this thread : 21
ASwaff400 , BigBlue79 , Booba5185 , catmechanic07 , chriss , DoubleDee , glc , herbz , Jaroot , JSoko , Klitch , markshere2 , michaelsnodgrass18 , Mike England , nine5flareside , pesposito75@yahoo.com , Russo2 , skatebowd , stroller , TheAmplified42 , whitesleeper
dump , f600
