Quantcast Knock sensor - Ford Truck Club Forum
Old August 22nd, 2016, 11:32 PM
MickJr's Avatar
MickJr MickJr is offline
Default Knock sensor
Can provision be made for a knock sensor in an '87 block? Like could a hole just be drilled and tapped in the same place on the '87 block as the knock sensor would have been on the '90 block?
Old August 23rd, 2016, 09:01 AM
MickJr's Avatar
Wait, is the knock sensor in the block or the back of the lower intake manifold?
Old August 23rd, 2016, 09:28 PM
MickJr's Avatar
Okay, long-winded post here.
So I took the knock sensor out of the '90 block and tried to find a hole in the '87 block that it would thread into. No luck. I tried finding a connector on the wiring harness that it would plug into, but again nothing. Then I looked at the block and saw a bulbous formation in the casting immediately below where the sensor would normally be (see pictures). However, there is no hole above it as in the '90 block. I measured the hole that the sensor came from and it was 1-1/4" deep. I transferred the measurement to the other block and 1-1/4" was nearly to the bottom of the bulbous formation. I'm convinced that the sensor should go there, but my question is why was there no sensor on that engine to begin with? When did they start putting the knock sensor on the 5.0L? (Sorry the pictures keep coming up sideways. No idea how to fix that or how to insert them in the post body.)
ID:	1253   Click image for larger version
Old March 20th, 2017, 09:13 PM
vjsimone's Avatar
vjsimone vjsimone is offline
1985 5.0L EFI has a Knock Sensor.
I believe the 87' had it on the back of the Block.
https://www.google.com/search?q=1987...YAnLZFbtfwvCM:
Alloy Snake , glc , harrison28 , JSoko , larrhy2 , mefreeman , MickJr , Steve , vjsimone
2015 Audi A3 - Can it Knock the CLA Down a Peg or Two? TheSmokingTire The Smoking Tire 0 May 12th, 2014 12:14 PM
O2 Sensor Info JSoko Garage Talk: Shop Class 101 0 October 13th, 2011 10:56 AM
Engine knock, different oil? Russo2 Garage Talk: Paint & Detailing 11 October 10th, 2011 01:47 PM
F150 fx4 phaser knock steveparkermx 2004-2008 Ford F150
16 July 9th, 2011 08:15 PM
knock , sensor
