Quantcast 1985 Ford Bronco wont hold a charge - Ford Truck Club Forum
Old May 24th, 2010, 10:46 AM
DIXIE FIX's Avatar
Images: 504
Default 1985 Ford Bronco wont hold a charge
The truck has been sitting for awhile but it used to run very well. Then it developed a problem of loosing charge and dying while driving. Now it wont even start. The alternator was the first place I looked and the battery the second. They both are fine. Where do I go from here? Starter? Is there any common problems like this with the Bronco? I need to get this thing running FAST.
Old June 2nd, 2010, 01:26 AM
The-LI-Redneck's Avatar
The-LI-Redneck The-LI-Redneck is offline
Images: 96
On some vehicles there is a charge regulator external on the alternator. If that is bad it will not charge the battery.
Old June 2nd, 2010, 08:05 AM
Were the alternator and battery replaced? If it is starting and then not holding a charge, then it is not the starter I would guess. Maybe LI hit the nail on the head hopefully. Good luck and let us know what happens.
Old June 2nd, 2010, 08:41 AM
unless a current drain has occured while it was sitting up, maybe something chewed into the wires
if the battery checks ok UNDER LOAD forget it
and we all know the altanator provides the juice for accessories and charging the battery
it seems like it is the problem
take it off and go to a shop that can check it on their bench
you got me courious now
Old June 2nd, 2010, 05:39 PM
pete59edsel's Avatar
Images: 101
Liked 6 Times in 6 Posts
Agree, alternator, starter has NOTHING to do with it. Good luck!
Old June 2nd, 2010, 06:53 PM
DIXIE FIX's Avatar
Images: 504
the alt, has already been checked twice and passed both times. The truck was starting but now its not
Old June 2nd, 2010, 08:03 PM
Images: 101
So it just turns over....correct? Distributor..Rotor....??
Old June 2nd, 2010, 08:25 PM
and ? "was starting" does it turn over??
sounds like a track problem, dont it Pete
Old June 2nd, 2010, 08:31 PM
DIXIE FIX's Avatar
Images: 504
its not doing anything at all now. No clicking nothing. Im gonna charge it back up next week and play around with it
Old June 2nd, 2010, 08:46 PM
take the cables off the battery now, sounds like you got a drain
check all accessories; you may have the interior lights turned on, the dash lights on, the cig lighter, back uplights, radio, some accessory , pull some fuses
« There is no previous thread | 1990 ford bronco fullsize »
WhatsAda
Bronco man fasterthanu1973 New Member Introductions 17 January 6th, 2010 03:44 AM
Hijackers Hold Mexican Plane On Runway RedHot150 General Discussion
3 September 10th, 2009 05:57 PM
City Drops Lewdness Charge Against Woman, 81 BigT67 General Discussion
0 August 6th, 2009 11:09 PM
Victims Of Gym Shooting Identified, Police To Hold News Conference RedHot150 General Discussion
0 August 5th, 2009 10:57 AM
1985 , bronco , charge , ford , ford bronco , hold
