Quantcast Vacuum and Emissions - Page 2 - Ford Truck Club Forum
Old September 17th, 2013, 08:41 AM
Tyler.purrington's Avatar
Tyler.purrington Tyler.purrington is offline
Could have someone messed with her the ecm? My check engine light works but I'd think it would be on since the sensors aren't hooked up?
Old September 17th, 2013, 09:59 AM
Yes and no. The EECIV ecu's are kinda funky with codes. Your best bet is to repair/replace the Emission System. A Junk Yard will be your best friend for the A.I.R plumbing. You can get away with running without a cat for the time being as it will have no impact on sensor readings. The EGR valve I wouldn't trust from a JY. A smog pump from a JY would be ok as long as it spins freely without noise. These engines run more efficiently and last longer when these systems are functioning properly. As far as someone messing with the ECU, I highly doubt it as the MAP system ECU's have very little to no aftermarket support for tuning. Only other thing could be the previous owner replaced the ECU with an incorrect one but even then I'd think your situation would be worse.
Old September 17th, 2013, 09:19 PM
It has everything but smog pump and cat, I was going to buy vacuum hoses and start running them. Do indeed a smog pump for this?
Old September 17th, 2013, 09:44 PM
The Smog Pump provides the air needed to run the A.I.R system. Ultimately, through a series of valves it will pump air to the exhaust ports or to the cat. In the exhaust ports, the air will ignite the hot unburned hydrocarbons coming out of the cylinder. Without this, the O2 sensor will see this and cause the ECU to react accordingly. The air to the cat is to help "light off" the same hydrocarbons and assist the heavy metal catalysts in "scrubbing" the exhaust gasses. It also increases the life of the factory style cat. Since the cat is downstream of the O2 it is not needed at the time being and the tube that runs to the cat can be vented into the atmosphere, Its just air.
Old September 18th, 2013, 12:06 AM
Okay thank you. A smog pump is only $80 new so I'll pick one up and start to run all the lines
Old September 18th, 2013, 10:05 AM
bikertrash3531 , Booba5185 , Bulldog74 , glc , JSoko , logix89 , Moore1991bronco , purple lady , Russo2 , shivey1 , TwoStroke , Tyler.purrington
muffler (emissions) michaelsnodgrass18 1992-1996 Ford F150
3 May 19th, 2013 02:05 AM
Vacuum/Emissions Bluegoose 1992-1996 Ford F150
7 April 28th, 2012 01:53 AM
Emissions Removal Ridgerunner 1973-1991 Ford F150
12 April 13th, 2012 08:12 PM
2004 F150 Failed Emissions Inspection in PA 2004FX4F150 2004-2008 Ford F150
33 December 21st, 2011 10:19 AM
California emissions vs regular emissions azfarrier 2011-2016 Ford F250 | F350
8 January 7th, 2011 04:10 AM
emissions , vacuum
