Quantcast Since I'm askin questions - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Expedition
Old July 8th, 2011, 10:05 PM
Stewy 39's Avatar
Stewy 39 Stewy 39 is offline
Images: 12
Default Since I'm askin questions
The wife's 98 expy keeps blowing the fuse for the dash lights. It seems to happen only when it rains, so I checked the most logical place, inside the hatch wiring grommet (because it's outside of the weatherstrip and the bending of the wires from opening the hatch and such) but it all looks good. Anyone else run into this?
Old July 8th, 2011, 10:11 PM
Joe'Bronco's Avatar
Joe'Bronco Joe'Bronco is offline
FTC ARTICLE CONTRIBUTOR
Images: 40
A bug in the electrical... To many diffrent things could be your problem here. What else goes out with the lights? Aftermarket Radio?
I would start by checking all the grounds.
TRUCK OF THE MONTH
*** June 2011 ***
F150 - Gotts no silencer Intake, straight piped 2.5" exhaust
Sold the Bronco
Old July 8th, 2011, 10:17 PM
Stewy 39's Avatar
Images: 12
Stock radio. Everything is stock and unmolested. How would a ground cause a wet short? If it got wet it would short to ground anyhow. I thought ground issues caused an 'open' which wouldn't blow the fuse, just make it not work.
Old July 8th, 2011, 10:44 PM
whitesleeper's Avatar
Default SHORT short
check the inside fire wall YET another common ford TRUCK/SUV problem ..
the windsheild leaks ..
i have seen it on vehics as new as 04
Old July 8th, 2011, 10:56 PM
Stewy 39's Avatar
Images: 12
Checked that. All dry. We're on the same page with our list of places to look!
Old July 8th, 2011, 10:59 PM
damn gremlins...
Tell her not to drive in the rain at night. Stupid question, did the check engine light go on at all, even if for a split second? Wiring issues are so hard to find sometimes. Another stupid question, what is the status of the battery? Last stupid question... I promise... have you inspected the fuse box under the hood?
Old July 8th, 2011, 11:06 PM
unplug and plug back in all fuses & relays under hood & inside
when doing so inspect for water or corrision on the spades
then when its out check socket with a flash lite for same
let us know what you find doing this
also look at all wiring connectors under the hood at firewall & fender wells
unplug them also & check
then look at where the wire goes into the plug around the tape
Old July 8th, 2011, 11:12 PM
Stewy 39's Avatar
Images: 12
As far as the status of the battery-It works? I dunno it hasn't given me any issues. No check engine light. Underhood fuse box shows no sign of corrosion. Blown fuses in my experience mean a short to ground. And in station wagons and suv's 99% of the time it's in the wiring between the body and the hatch where the wires have to make repeated extreme bends. So that's why I guess I'm being short sighted about what the issue is. It should be there- but it isn't. If i did have a check engine light how would it be related?
Old July 9th, 2011, 04:36 AM
It's prob a leaky windshield, I'd get it fixed before it takes out your gem module
Old July 9th, 2011, 08:15 AM
Stewy 39's Avatar
Images: 12
I'm gonna go dig into it "shortly."
ASwaff400 , DoubleDee , FredDog01 , Joe'Bronco , JSoko , Klitch , MetroD , nine5flareside , pete59edsel , Russo2 , screwon23s , Stewy 39 , whitesleeper
SAS questions. Russo2 Garage Talk: Solid Axle Swaps 3 June 5th, 2011 01:33 PM
302 Build Questions... iamosolo Garage Talk: Engine & Drivetrain 3 November 29th, 2010 10:37 AM
Lift spring questions. lil_bizzy 1997-2003 Ford F150
5 May 4th, 2010 07:13 PM
Questions arise over story of runaway Prius BigT67 General Discussion
0 March 14th, 2010 08:09 PM
Questions to ponder TazDevil07 General Discussion
4 July 29th, 2009 04:46 PM
askin , questions
