Quantcast 99 f250 5.4 2v engine knock - Ford Truck Club Forum
Old September 4th, 2019, 07:35 PM
Jrp79's Avatar
Jrp79 Jrp79 is offline
Default 99 f250 5.4 2v engine knock
192k. Unplugged the cop individual with no sound change. Knock comes and goes at idle but if the ac kicks on or put in gear it goes away.when put back in park or ac shuts off it comes back. Hit the gas in park or gear knocks there.
https://youtu.be/WxshB7ZEnTQ
Old September 4th, 2019, 08:54 PM
Liked 103 Times in 100 Posts
If it only knocks when the A/C compressor is not running, it's probably the compressor clutch.
harrison28 (September 5th, 2019)
Old September 4th, 2019, 09:08 PM
Jrp79's Avatar
When ac compressor kicks on or when put in gear engine idles down so no knock.when engine revs over 1k the knock is there
Old September 4th, 2019, 11:54 PM
As a test, pull the drive belt for a couple minutes and see if it still knocks. If it doesn't, it's something that's driven by the belt. Use a stethoscope to try to find the source.
Old September 6th, 2019, 08:15 AM
Jrp79's Avatar
If a main bearing is bad will it still have good oil pressure cause cold and normal temp pressure was still good
Old September 6th, 2019, 07:02 PM
Jrp79's Avatar
Engines pulled..bearings look good.i did find what looks to be some type of brown plastic thats broke and i found it between the last main bearing cap and rear main seal housing.i dont know what it could be.
It looks like the same thing the oil pick up tube is made out of but nothing looks broke on it
Old September 10th, 2019, 02:47 PM
Jrp79's Avatar
This is what i found
Pics didnt post.does it take time for them
Old September 10th, 2019, 03:24 PM
You have to resize your images. 244kb max file size.
Old September 10th, 2019, 03:55 PM
Jrp79's Avatar
Try these pics
glc , harrison28 , Jrp79
Knock sensor MickJr 1973-1991 Ford F150
3 March 20th, 2017 09:13 PM
87 F250 Engine swap Brokemech Garage Talk: Engine & Drivetrain 1 November 10th, 2014 11:50 PM
1992 F250 Engine swap tdem630 1992-1997 Ford F250 | F350
5 February 24th, 2013 02:15 PM
Engine knock, different oil? Russo2 Garage Talk: Paint & Detailing 11 October 10th, 2011 01:47 PM
F150 fx4 phaser knock steveparkermx 2004-2008 Ford F150
16 July 9th, 2011 08:15 PM
engine , f250 , knock
