Quantcast F-250 4 speed v6 4.9 - Ford Truck Club Forum
Old January 12th, 2016, 11:08 PM
Rhino1989F250's Avatar
Rhino1989F250 Rhino1989F250 is offline
Exclamation F-250 4 speed v6 4.9
Hello i just bought my 89 f250 2wd 4 speed and was having trouble with the starting the truck at first but found out i was pressing down on the clutch far enough. So that is My problem my clutch is stiff and i have step all the way to the floor for it to start and to shift gears. Want to know about how fix the clutch to raise it of the floor? sorry if it doesn't make sense.
Thank You
Old January 13th, 2016, 02:05 PM
Liked 114 Times in 110 Posts
First off, that's not a V6, it's an I6.
Find the clutch pedal safety switch and disconnect it. It should be somewhere on the pedal arm. If that doesn't work, then bridge the connector you disconnected. I don't remember whether it's a make or break switch.
As far as adjusting the clutch, it's not adjustable. You may have to replace it.
glc , harrison28 , JSoko , Rhino1989F250
Speed Density Tuner lanejesse85 1992-1996 Ford F150
2 June 29th, 2014 02:15 PM
4 speed tranny swap Trav_450R 1973-1991 Ford F150
8 August 26th, 2012 04:22 PM
6 Speed Trans Leaking sbellinghausen 2009-2014 Ford F150
11 February 27th, 2012 06:54 PM
speed sensor issues fightlife1437 1997-2003 Ford F150
5 December 26th, 2011 06:47 AM
3 speed hotrodf100 1973-1991 Ford F150
13 October 19th, 2011 07:43 AM
f250 , speed
