Quantcast No power / speed - Ford Truck Club Forum
Old March 23rd, 2018, 01:22 AM
wclrjohn's Avatar
wclrjohn wclrjohn is offline
Cool No power / speed
I'm buying a F350 gas with 460 (7.5L) automatic from a friend. Original problem was bad oil pump. The mechanic he took it to drilled thru the block trying to fix a broken bolt. Mechanic installed a used engine from an econoline van same size engine. When he picked it up it would not go faster then 20 MPH. He then bought a different motor on line (used) had it installed and still same problem. I started the truck yesterday and after 2 -3 minutes valves stopped rattling (engine had been sitting for few months without being started). I did notice allot of rattling coming from CAT. I couldn't take it for a drive (it was barried behind years of trash) but for the most part it was idling on it's own I felt the exhaust and felt no misfire, check engine light was not on. Could it be a vacuum line going to the transmission? Oh by the way it's a 4 X 4. strange that two different motors would do the same thing. Any ideas before I put a 3rd motor in it.
Old March 23rd, 2018, 10:22 AM
The cat is plugged or you have another exhaust blockage.
harrison28 (March 23rd, 2018)
Bob S , Bulldog74 , cv51 , Dino , glc , harrison28 , wclrjohn
F-250 4 speed v6 4.9 Rhino1989F250 1987-1991 Ford F250 | F350
1 January 13th, 2016 02:05 PM
4 speed tranny swap Trav_450R 1973-1991 Ford F150
8 August 26th, 2012 04:22 PM
speed sensor issues fightlife1437 1997-2003 Ford F150
5 December 26th, 2011 06:47 AM
3 speed hotrodf100 1973-1991 Ford F150
13 October 19th, 2011 07:43 AM
power , speed
