Quantcast 2018 5.0 Oil Drain Plug ??? - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-100 | F-150 SERIES > 2015-2020 Ford F150
Old May 13th, 2019, 11:20 AM
Question 2018 5.0 Oil Drain Plug ???
my NEW 2018 5.0, 2,000 miles
this Truck has been on the Dealer lot since Jan 2018 (well that's the date on the window sticker)
I bought it in Feb 2019 with 13 miles
as the oil has been in there over 1 year I going to change it & filter (MotorCraft oil & filter)
I looked at the drain and never seen a plug like that
any Tips or Tricks on taking it off
Old May 13th, 2019, 11:51 AM
Not sure if it's the same as an Eco boost motor,...but in this video the guy uses channel locks.
Old May 13th, 2019, 12:11 PM
Thanks for the Video
that's what I have "that yellow thing"
and the cross bar
the 2018 5.0 holds 8.8 quarts
oil filter type & location is similar to my 5.4
Old May 13th, 2019, 03:54 PM
Oil & Filter changed
Hey Chris, I really appreciate that video, it prevented me from making a mess
I used channel locks to loosen the drain plug
then slowly turned it by hand until a small stream of oil came out and I held the plug in the drain hole, it took awhile to drain 8.8 quarts, but I didn't get any on my arms or the floor
and yes, the torsion bar is dead in the way of the oil stream
the drain hole is 1" and if you were to pull the plug away I'm sure all 8 qts would come out very fast and a heavy stream of oil would go everywhere
the oil and trans pan are plastic
I got a little nervious when I removed the factory filter as it's not the same looking as the MC FL 500s
I went and double checked that I had purchased the correct filter
the filter has a plastic drain pan under it to funnel the oil toward the front, and just like my '06 5.4 most of the oil goes out and over the back side and just a little out the front
you have to be quick with the catch pan to keep the oil off the floor
Old May 13th, 2019, 03:58 PM
Glad it helped. Plastic oil pans? Wow, the must do that for weight.
Old May 26th, 2019, 06:53 PM
to add to POST #4
let the oil pan & plug cool enough to touch
so you can hold the plug in the hole so as not to make a mess (this is an important step, hold the plug)
harrison28 (May 28th, 2019)
Old August 22nd, 2019, 07:07 AM
ALEOTTO's Avatar
ALEOTTO ALEOTTO is offline
I bought the RONIN Factory drain l oil drain pan plug and did a full review. For those unware, the yellow one from Ford is a pain. This one tries to lessen the pain of changing your oil. It gives a controlled flow, has a magnetic tip in the pan and it looks good..
Old August 25th, 2019, 10:48 AM
yikes that thing is costly
(View-All Members who have read this thread : 68
ALEOTTO , AlfredHof , Billygenna , BrianRed , Carlosjekly , Carrollhof , CecilSag , Charlessam , ClezeripLover , Clydetaw , Danielfuh , DavidGag , Debracet , DiplPoothekayah , DonaldGOR , DonaldVaf , DonaldWoche , EmersonSwone , EmmittImmap , ErnestWiche , Franciswem , FrankCoosy , GeraldHek , glc , harrison28 , her , Irinagluch , Jendiump , Jesseplosy , JosephCar , JSoko , JulioNON , KeithFoult , Keithped , Kennethdof , Latiaspell , LeonelCox , LouiseDex , Martynaw , Michaelanify , MichaelDug , Mikoelhiz , nas1955 , Nathanporse , Olgahem , PatrickNob , Paulinewiz , Ramonvog , RaymondDef , Richardkig , RobertDooda , RobertEmavy , Robertnut , Rodneyvat , RogelioBut , RopnazTus , RustyPile , Shanehib , skatebowd , sochi.cat/vek , Stephencluby , TimothyNut , ursulaaa , Wilbursep , Williamidons , WilliamOrdes , WilliamSlali , XRumerTest
TPMS Sensor F-350 2018 Specs Genek 2017-2020 Ford F250 | F350
1 November 26th, 2018 02:21 PM
Spied: 2018 Ford F-150 Diesel Hybrid? JSoko More Special Edition F150's
3 January 9th, 2017 08:42 AM
5.4 Block Drain Plugs JSoko Garage Talk: Engine & Drivetrain 7 November 15th, 2014 11:04 AM
Plug ? Ridgerunner Garage Talk: Electrical & Lighting 10 May 13th, 2012 09:32 PM
How to Use a Self Tapping Drain Plug JSoko Garage Talk: Shop Class 101 0 March 21st, 2012 03:30 PM
2018 , drain , oil , plug
