Quantcast Automatic Hubs - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1992-1996 Ford Bronco
Old April 5th, 2011, 09:29 PM
ANDYSHUFORD's Avatar
ANDYSHUFORD ANDYSHUFORD is offline
Default Automatic Hubs
I have a 95 bronco and thefront hubs lock when ever they want i have looked for a issue but cant find it. what controls the auto hubs and how do i fix it with out replacing the hubs i would like to keep the autolocking hubs. also where can i get an actuator for the transfercase
Old April 5th, 2011, 10:27 PM
T-case: electric shift motor? Check any local parts store, they should have one either on hand or near by.
IIRC, those hubs are prone to blowing apart, sometimes in a big way. Heard stories of parts going flying past spotters on trails.
Pretty sure with those hubs theres a spring in them, and its waiting for torque from the driveline to cause it to engage. Make sure you havn't PACKED the hubs, just a fair coat of grease will do. Even though I've also heard people say use ATF to lube them instead.
ANDYSHUFORD , ASwaff400 , BigRob , brads93bronco , goldman , JSoko , Klitch , Lifted_Bronco , Moore1991bronco , rick wilcoxson , Russo2 , Scotts Black FX4 , simperfi762 , whitesleeper
question about automatic gearbox Bastien 2004-2008 Ford F150
17 January 17th, 2011 02:31 PM
Ariz. lawmaker takes aim at automatic citizenship BigT67 General Discussion
0 June 16th, 2010 03:24 PM
1995 bronco , automatic , hubs
