Quantcast Wiring issue - Ford Truck Club Forum
Old November 28th, 2011, 05:29 PM
JimGreen's Avatar
JimGreen JimGreen is offline
Default Wiring issue
After a recent off road experience I discovered that something had ripped the wiring to my license plate lights off. When it happened the 15 amp fuse for my dash lights and parking lights blew also. I replaced the fuse and tried to repair the wiring but when I turned my lights on the fuse blew again. Does anybody have a wiring diagram for the license plate lights? There must be something else that I am missing.
Old November 30th, 2011, 09:33 AM
follow the wire back as far as you can, if nothing found you may have to uncover them
that hot wire is grounding out
there has to be a point where the wire is secure thats where the tension took up this is the place I would check to find that loose/broken wire
get a test lite and probe through the insulation
Old April 5th, 2012, 07:37 AM
shree12's Avatar
shree12 shree12 is offline
I think, first you should check the electrical line at the lower tailgate. Because, the license plate wiring runs through a rubber accordion type piece.
Old April 6th, 2012, 12:15 AM
thats a geat place to start, as most never think of that
Old June 26th, 2013, 10:24 PM
blueovalmastertech's Avatar
blueovalmastertech blueovalmastertech is offline
what is the year and model?
(View-All Members who have read this thread : 25
1Barret1prion , ASwaff400 , BigBlue79 , BigT67 , blueovalmastertech , Booba5185 , dlmabe331 , DoubleDee , gimbrass , glc , HawaiianF150 , herbz , i6lover , JBC Ford , JerryR , JimGreen , John Faczak , JSoko , nine5flareside , Russo2 , shree12 , skatebowd , whitesleeper , WilliamSlali , WilliamStali
Flooding issue BigBlue79 1973-1991 Ford F150
26 October 17th, 2011 02:36 PM
1995 F150 Tailgate Issue nine5flareside 1992-1996 Ford F150
2 January 4th, 2011 11:29 AM
Looking for similar idle issue BigT67 1997-2003 Ford F150
11 June 14th, 2010 09:46 PM
Tilt column issue? foosefan 2004-2008 Ford F150
1 April 29th, 2010 10:58 AM
Super Wiring Two Guys Garage Two Guys Garage 0 January 29th, 2010 08:59 PM
issue , wiring
