Quantcast speed sensor issues - Ford Truck Club Forum
Old December 23rd, 2011, 10:59 AM
fightlife1437's Avatar
fightlife1437 fightlife1437 is offline
Default speed sensor issues
there's an issue in my speed sensor circuit I just replaced the speed sensor itself so it's not that is there anything I can do rather that replace the speed sensor harness?
OIF 09-10
infantry follow me!
Old December 23rd, 2011, 06:50 PM
can you give us some more information as to what is going on.
Old December 24th, 2011, 11:59 AM
'Queen of Battle' thanks
like what kinda Truck and year model
what is the actual issue
Old December 25th, 2011, 04:58 AM
it's a 97 F150 the speedometer does not work at all I had my computer checked and it says that there is an issue with my speed sensor circuit the speed sensor on my model is located in the drivetrain the sensor itself is brand new.
OIF 09-10
infantry follow me!
Old December 25th, 2011, 09:19 AM
On 2 wheel drive trucks.
If you have a 4R70W Transmission you have two sensors. The one on the tail shaft is the OSS (Output Shaft Speed) sensor used only by the PCM Computer. Then you have the one on top of the rear end in the center, the VSS (Vehicle Speed Sensor) for the Speedometer (PSOM), ABS, and speed control. This one is all so called the DSS and the ABS sensor by some auto parts outlets and Ford dealers.
If you have a E4OD Transmission then you just have the one on the rear end, the VSS sensor. It is used fro the Speedometer (PSOM), Speed Control and the ABS system.
The PSOM also sends information to the PCM Computer for shifting the transmission in both transmission types.
You may also have problems inside the rear end, bad wiring or a bad PSOM causing this problem.
On a 4X4 there is also a speed sensor inside the Transfer Case Assembly but it is only used by the Shift Control Module.
Not sure if your Truck has a VSS on the transmission. It does have a rear axle speed sensor located on the top of the rear differential housing itself. Access is very simple. Simply disconnect the two-wire electrical connector to it and remove the one 10mm or 13mm bolt that secures it to the top of the housing and remove.
Hope this helps.
it is on the tail shaft of your transmission.you screw it all the way in and back it out one half turn and adjust the jam nut
The Programmable Speedometer/Odometer Module (PSOM) receives input from the Rear Anti-Lock Brake Sensor (RABS) mounted on the rear axle differential. The PSOM sends this input signal information to the Speed Control module and the Powertrain Control Module (PCM).
If something is loose it wont work , Check all connections, look for dirt left in a connector, it wont hurt to spray contact cleaner in there to flush anything out
Old December 26th, 2011, 06:47 AM
will be sure to do that I appreciate the info
OIF 09-10
infantry follow me!
ASwaff400 , bikertrash3531 , DoubleDee , fightlife1437 , HawaiianF150 , jleerider , js1990 , JSoko , katrobb@live.com , MiracleMax , Mwebb , nine5flareside , Russo2 , whitesleeper , will
Electronic 4wd Issues herbz 2004-2008 Ford F150
26 May 26th, 2013 12:16 AM
Front Tank issues tity04 1992-1996 Ford F150
15 December 4th, 2011 09:48 PM
BRAKES!!! issues... ASwaff400 1992-1996 Ford F150
4 October 4th, 2011 10:18 PM
3 July 10th, 2010 09:39 PM
4x4 Issues - 97 Klitch 1997-2003 Ford F150
33 January 3rd, 2010 02:57 PM
issues , sensor , speed
