Quantcast Oil Pan gasket replacement - Page 2 - Ford Truck Club Forum
Old November 22nd, 2012, 08:13 PM
HiRoller's Avatar
HiRoller HiRoller is offline
The deed is done !! Altho it was a PITA, I've done worse.
My friend with the shop and lift I was planning on using, got flooded with work and that left me in the driveway at the house. The weather here in Indy has been nice so I dug in and used the "in vehicle service" method from the 1992 engine service manual, which is basicly the same thing he described to me.
I had already ripped off all of the exhaust piping and manifolds so there was a pretty good head start. I removed the Rad and fan shroud, unbolted the motor and tranny mounts, jacked up the motor and trans high enough to get small blocks of 2x4 under all of the mounts, dropped the pan down on the cross member, unbolted the oil pump and pick up tube and dropped it in the pan. At this point you can weasel out the pan. I found my pan was very rusty between the paint and the metal, so I bought a new pan from Advance along with a Fel-Pro one piece silicone gasket, and new oil pump. Reversed the disassembly and drank several beers.
1992 Nite Style Side SB 5.0 E4OD
2014 Fusion SE Ecoboost
Old November 23rd, 2012, 07:48 PM
The Frankster's Avatar
Liked 12 Times in 9 Posts
Two thumbs hiroller. Way to go.
Old November 24th, 2012, 12:21 PM
good work
is that gasket the blue one ? if so it will never leak
Old December 1st, 2012, 10:31 PM
HiRoller's Avatar
Yep ,it's the blue one, looks to be a quality part. No leaks so far !!
Old December 2nd, 2012, 12:05 AM
Old January 16th, 2013, 10:35 PM
rick wilcoxson's Avatar
rick wilcoxson rick wilcoxson is offline
This is my first post, looks like a great site! I had the same problem with my 92, 302
bronco, also. so we are putting in rebulid! I am sure I will have lots of guestions, soon!
want to bring it back to all mmost new.
  #17
Old January 21st, 2013, 02:33 PM
Bring 'em on Rick. Some super guys that will help you out. I was reading some service bullitins on the webb a while back and a lot of problems with rusted oil pans. I'll see if I can dig that up again.
  #18
Old February 23rd, 2013, 10:32 AM
Lostin90s's Avatar
Good job I was going to chime in the dropping of oilpump tube
Adrien , BigBlue79 , bikertrash3531 , Booba5185 , Bulldog74 , C-DogAK , cblachly7808 , HiRoller , jared96 , jones03100 , JSoko , Lostin90s , MetallateM , michaelsnodgrass18 , rick wilcoxson , rikard , Russo2 , The Frankster
1995 F150 - Blown Head Gasket nine5flareside 1992-1996 Ford F150
17 August 21st, 2012 02:52 PM
9" carrier gasket question BigBlue79 1980-1986 Ford Bronco
5 December 24th, 2011 03:13 PM
Blown Head Gasket 7.5 460 DIXIE FIX Garage Talk: Engine & Drivetrain 5 January 17th, 2011 07:38 AM
Tie Rod Replacement DavidS827 1997-2003 Ford F150
5 September 9th, 2010 05:30 PM
LED replacement bulbs RedHot150 2004-2008 Ford F150
16 August 20th, 2009 08:39 AM
gasket , oil , pan , replacement
