Quantcast Steering Column Bearings - Ford Truck Club Forum
Old November 10th, 2012, 12:27 AM
commandotom's Avatar
commandotom commandotom is offline
Default Steering Column Bearings
Hello,
Newbie here on Ford Truck.
1984 F350 Diesel Dually, upgraded with a new (Jasper) 7.3 and 5-speed with single mass clutch.
Steering Column Bearings are shot. Ford told me the bearings that were removed are longer available. I went to my '83 donor truck, pulled the column and you guessed it... same bearings. Bearing supply has correct OD/ID but the width is greater (larger). Has anyone else out there run into this problem. Do these bearings cross with anything else? Suggestions???
Thanks kindly in advance.
Tom
Old November 10th, 2012, 06:50 AM
I looked on LMC TRUCKS and all they offer is up to a F250
I have had excellent luck in the past by either copying the bearing number or take it to an auto store and they can cross reference the # to an in stock bearing
all in all it should not be hard to find a new bearing
and if for some reason you can't find one, get the '83 bearing and shim it to fit
have you tried an '84 donor
Old November 10th, 2012, 06:55 AM
oh, Welcome to the site
when you get a chance do an intro in the 'New Members' section
and put up a pic of your truck, we like truck porn
are you an Ironworker?
Old November 10th, 2012, 11:54 PM
Check bronco graveyard, LMC and National Parts depot.
I know bronco graveyard has them for the 87-91 and 92-96, so they probably have them for the 80-86 as well. Good luck to ya.
Old December 19th, 2012, 07:25 AM
I Moved spam post.
-Blue.
I knew I smelled something
Last edited by JSoko; December 19th, 2012 at 04:58 PM. Reason: Spam post by gomez.
Old December 19th, 2012, 11:57 AM
to FTC commandotom!
Old December 19th, 2012, 12:01 PM
Those are all good suggestions, worse comes to worse, go to pull a part or junkyard and see if you can find a whole column, I was always under the impression the columns were the same across the F150/250/350 and Bronco's.
BigBlue79 , Bobbybe , commandotom , faof2 , gomez000123 , JSoko , KarenP , Russo2 , WilliamStali
1992 F-150 Steering Column Trim jelarf Auto Parts Wanted
0 August 20th, 2012 03:34 PM
Steering Column bearings 1977 F-250 4x4 Custom 1948-1986 Ford F250 | F350
10 February 10th, 2012 04:02 AM
How to remove steering column and pedal assembly 87-91 Russo2 Garage Talk: Shop Class 101 7 January 8th, 2012 11:11 AM
Steering column whitesleeper Auto Parts For Sale
0 March 13th, 2011 06:05 PM
Steering column Russo2 1973-1991 Ford F150
8 January 3rd, 2011 06:40 PM
bearings , column , steering
